  1. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I have a MKV file with an aac audio track I'm trying to convert to ac3. The program (https://www.videohelp.com/tools/PopCorn-MKV-AudioConverter) has always performed flawlessly for me so I am somewhat confused with this error and was wondering what I could have done to trigger an error message that says "conversion complete or program disabled" I have tried other mkv files with aac and it works, only this particular file. I have checked for compressed headers etc...
    MediaInfo report.
    Video
    Format profile                           : High@L3.1
    Format settings, CABAC                   : No
    Format settings, ReFrames                : 2 frames
    Codec ID                                 : V_MPEG4/ISO/AVC
    Duration                                 : 2h 23mn
    Width                                    : 1 280 pixels
    Height                                   : 546 pixels
    Display aspect ratio                     : 2.35:1
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : A_AAC
    Duration                                 : 2h 23mn
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    many thanks for any assistance
    You could also try MKV2AC3.
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Haha yes I tried that with a big fail as well. My longwinded workaround was to use ConvertXtoDVD. I then extracted the audio and laid that into the original MKV - so good video and sound. It's really an academic question as to why the problem with this file and no other similar...?
    My fixed file details.
    Video
    Duration                                 : 2h 23mn
    Height                                   : 546 pixels
    Language                                 : English
    Default                                  : Yes
    Forced                                   : No
    Audio
    Format                                   : PCM
    Codec ID                                 : A_PCM/INT/LIT
    Duration                                 : 2h 23mn
    Bit rate mode                            : Constant
    Bit depth                                : 16 bits
    Default                                  : Yes
    Forced                                   : No
