I have several vobs , would like to figure out what they were originally. And then convert them back to their original format. Is there a program that can tell me what they are originally and then do the conversion? John
Vob files are found in dvd-video. This may have been the original format for this particular video.
If they were converted into dvd-video from something else, you won't be able to find out what that original format was. And converting will lose a bit of the existing visual quality of your video.
Vob files by themselves aren't particularly useful...they will play on a computer using something like MPC-HC or VLC. You don't have the ifo and bup files that go with them?
What do you want to accomplish when working with these vob files? It is easy enough to re-author them to dvd-video, or merge them and convert to something else, like H264. -
No program I am aware of. You can open one in MediaInfo and it may tell you more about the VOBS themselves.
If you re-encode them once again, even to a possible original format, the quality will suffer.
If they are just VOBs with no VIDEO_TS folder or any IFOs or BUPS, you could rename the extension .mpg instead of .VOB.
Or maybe one method to convert the VOBs back to a DVD, if they are all from one source and you don't want to lose quality:
https://forum.videohelp.com/threads/194163-SPLIT-A-LARGE-VOB-FILE-INTO-1GB-CHUNKS-AND-AUTHOR
Other members probably have suggestions, also. -
VOB files from standard DVD are MPEG2. Change the filename from to .mpg or .mpeg. Or use an authoring program to build a new DVD compilation, assuming the vob's have similar and compatible characteristics. Do NOT re-encode MPEG2 just for the hell of it. Video encoding is lossy.
I am actually trying to seperate the mpegs from the vobs and create my own disk. Can I do this? Can I make one big vob then seperate the video into mpegs then burn to disk. John
Is there a program that can take an iso and can give me files when winrar says no archives found? John
Mkv to xvid program with compression check needed
By joearmstrong in forum Video ConversionReplies: 19Last Post: 28th May 2013, 08:04 -
Recommend video conversion program for older hardware?
By mr-scarface in forum Video ConversionReplies: 1Last Post: 4th Mar 2011, 03:29 -
Help needed for video conversion : Winavi
By leoboms in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2010, 14:48 -
Program for video conversion VC-1 to H.264
By wisitch in forum Video ConversionReplies: 1Last Post: 5th Apr 2010, 16:00 -
Easy Capture Program needed
By NautTboy in forum DVB / IPTVReplies: 2Last Post: 19th Feb 2010, 11:32
