Hi all,
I have this H264 MP4 AVC (part 10) movie of 720x440 resolution. It looks very stretched if loaded into VLC with the aspect ratio set to "default". Once I change it to 2.35:1 it looks fine.
Is this an error made while encoding?
My intended player (wd tv live) has no option for forcing aspect ratio - unlike vlc, potplayer etc...
So, I guess, I need to fix the file? If so, how? Must I re-encode?
TIA
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=woody+a...oody+allen+dvd
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=take+th...+money+and+run
As examples. Or are you looking for something else? -
By saying "I've found 44 of his movies in decent resolution and quality", I don't think the O.P. is buying this stuff. Anyway, Woody as a writer is known to have worked on 77 films/TV movies/TV shows, not counting specific episodes of productions like The Show Of Shows. Inferior pirated copies of his work are all over the place.
yes, 70+. but only around 50 directed. and, yes, found means found. inferiority though is questionable: many rips appear to be professionally done and there are uncompressed sources as well.
Change Aspect Ratio of H264 or DIVX in MP4
By petdeal in forum Video ConversionReplies: 2Last Post: 1st Aug 2012, 11:03 -
Need help with aspect ratio of MKV / M2TS file
By FulciLives in forum Video ConversionReplies: 14Last Post: 5th Jul 2012, 16:45 -
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 12:31 -
NTSC DV to H264 MP4: Vegas renders wrong aspect ratio
By zigmond in forum EditingReplies: 30Last Post: 16th May 2011, 02:54 -
Change aspect ratio, Deinterlace and date stamp H264 video.
By leec in forum Newbie / General discussionsReplies: 0Last Post: 23rd Feb 2010, 08:27
