Hello
I have a very unusual requirement I need advise on:
I have a 2 minute video that I need to loop 100x, and then stop. I don't wish to generate a massive 200 minute encoded file. Rather I would encode only a 2 minute single loop, and somehow set either playlist or chapter flow MP4 metadata to get it to loop exactly (and only) 200x.
However, I really don't know how to do this.
I really would appreciate any help!
P.![]()
mpc-be has the option (o) Play -- [200 ] times(s), under
options\playback
in other words, set it repeat 200 times. but, it only does this on correctly encoded/muxed videos. i am not able to get repeat playback to work correctly on some hevc->mp4 videos. it seems to stop at the end of playback and play an audio file from somewhere else while still showing the last frame. strange. anyway. i took one my very short happauge ts recordings and it repeated x many times i test setted it to, i.e., 5x.
edit: maybe this has something to do with that issue i mentioned. might be a bug.
Code:+ Added the ability to automatically open external audio files and subtitles. Blu-ray name - root folder name or disc label (when opening a disc) - is used for searching;
Sorry, I should clarify.
I need the repeat 200x to be part of the mp4 metadata container control. It won't work for me to set a given player to loop it 200x, since I need to distribute it without my having any control over the choice of players that the recipients are using.
So the 200x repeat control needs to be 'inherent' in my file. -
There is no such metadata for MP4 container that specifies what you want to do
According to wikipedia, there is menu support in MP4:
http://en.wikipedia.org/wiki/Comparison_of_container_formats
I would have thought then that a 'playlist' of multiple contained videos (or a single video referenced repeatedly) would be possible. Is it not?
What about .mov?
Any other suggestions? -
then, the only alternative is to create your own player that does, and distribute that along with your video(s).
Yes - In theory, there is "menu" support in many container specifications, but in practice, none of them have it implemented properly.
Even if you did for your file, the software/hardware player would need to have implemented support
e.g here is how to do menus for MP4
http://forum.doom9.org/showthread.php?s=&threadid=66583
Quicktime might be able to do it , but it would only play on quicktime, other players won't support those other features
convert h264 avi container to mp4 container
By azukich in forum Video ConversionReplies: 0Last Post: 6th Apr 2013, 17:09 -
need to put content of FLV container into MP4 container
By arraboy in forum Newbie / General discussionsReplies: 3Last Post: 29th Jun 2012, 20:52 -
M4V to MP4 Container help
By Cornholio77 in forum Video ConversionReplies: 5Last Post: 1st Jan 2012, 04:28 -
AAC 2.0 vs AC3 5.1 for h264 video inside MKV container
By ekred in forum AudioReplies: 9Last Post: 26th Oct 2011, 13:36 -
Help! - How to put xvid into an mp4 container.
By jamsponge in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2011, 11:54
