Hi;
I have made a couple of threads asking for advice on capturing some VHS Home Movies one link is at the bottom of this post.
I ended up capturing using WinTV 7 and my Hauppauge HVR1300, WinTV captures to MPEG2 TS.
I tried using Virtual Dub but just couldn't get any decent captures so I am stuck with WinTV 7 and my Hauppauge HVR 1300.
Anyway I have managed to capture most of the VHS tapes and the results are OK, the video is no where near as good as the original but it will have to do? However the last couple of tapes seem to be problematic, the playback on the screen of the TV / Video Combi that I am using to play them is fine but the video in WinTV is split halfway across the Vertical??
Attached are a couple of files one showing the TV Screen Display and the other the capture, the capture has been converted to mp4 using MPEG Streamclip and the TV Screen was captured using my smart phone, the black diagonal bars where not visible on the screen
Anyone got any ideas why these two tapes are exhibiting this problem, I think I have successfully captured tapes recorded with the same camera, it was a borrowed camera but the settings could have been changed??
Heres one of my threads: https://forum.videohelp.com/threads/358871-VHS-To-PC-Or-DVD-Editing-and-DVD-Authoring-Help
Oh and when playing back on my Panasonic 40 Inch Plasma I have two black borders either side of the Screen but when viewing on my Laptop its OK, i guess the captured Aspect Ratio does not suit my panny?
The time base probably just isn't clean enough for the capture device. First try a different VHS deck and/or a different capture device. If neither of those work a full frame TBC or a DVD recorder with TBC may help. Oh, if you have one sitting around, you might as well try a different cable. It's not likely to help but it's free and will only take a minute.
The VHS recording is 4:3 display aspect ratio so the picture shouldn't fill a 16:9 screen. Your laptop may be set to stretch the video.Last edited by jagabo; 3rd Nov 2013 at 21:33.
Do you happen to have a digital video camera with a composite input?
When I converted all of my old analog VHS and 8mm home videos I used a Digital8 camcorder and connected it via Firewire. I got much better results than any USB video capture. -
Try the JVC S-VHS stabilizer.
It often works.Want my help? Ask here! (not via PM!)
I am on a bit of a tight time schedule packing up to move back to the UK and was tasked to complete digitizing these VHS tapes before we left and ditch the pile of VHS Cassettes we have been lugging around, some for over 20 years!! I may be able to pick up / borrow another VHS player but the chance would be slim. Had to google TBC - again not an option at this stage.
I do however have another cable
I may have to keep the 2 x VHS that are suffering with this problem and try again in the UK. -
I do have a digital video camera (Panasonic NV-DS60) but looking at it its got 3.5mm to Composite Output, a DV connector (Looks like small USB) for connecting to a PC for still captures only and another 3.5mm socket labelled 'To PC'. It also has an S Video (Probably Out) to connect the Camera to a TV is the TV has no Composite Input.
According to CNET there are no video inputs on that camcorder.
http://reviews.cnet.com/digital-camcorders/panasonic-nv-ds60-camcorder/4507-6500_7-31527017.html -
Nope, that one won't work.
I wonder if you can get a camcorder with any sort of video input. If I remember correctly the EU taxes video recording devices differently, so in order to keep the list price down, they take away the ability to record from a Line in.
I used a Sony TRV-460 - but it is the north American/NTSC version.
Sound problem during vhs capture
By monks19 in forum Capturing and VCRReplies: 13Last Post: 6th Jan 2013, 12:26 -
Please help! Problem with using TBC to capture VHS tapes.
By jrodefeld in forum Capturing and VCRReplies: 9Last Post: 9th Jun 2011, 17:08 -
D-VHS MPEG2 Transport Stream Capture v0.3.0.6 Problem
By eddiegnz1 in forum Capturing and VCRReplies: 4Last Post: 11th May 2011, 18:51 -
Very strange VHS to PC capture problem
By fredhoward in forum Capturing and VCRReplies: 45Last Post: 9th Feb 2010, 08:30 -
VHS Capture Problem
By sdculp in forum Newbie / General discussionsReplies: 7Last Post: 15th Nov 2008, 08:58
