    Nov 2013
    Los Angeles
    Hi,
    I'm a video tool novice.
    I need to merge a collection of JPEG images into a single Mp4 file. (It's a training class and I want to upload it to YouTube for students to watch.)
    Can an expert post the steps if you know them. Thank You.
    (Later I want to add words to explain the slides. If that's possible.)
    Thanks Again for any help.
    Milton.
    Dec 2005
    Canada
    Using version 2.5.6 (I can't get the new 2.6 version to do much of anything).
    The image files should be sequentially numbered and the same resolution.
    Click File > Open and select the first image (or just drag it onto the window).
    On the side menu, set as shown.
    Click File > Save > Save video and give it a name including the extension;e.g. clip.mp4
    Nov 2009
    There's a program in the tools section of this site called DVD slideshow GUI. It will let you build a slideshow from you image files.
