I am outputting video from a software called OnTheAirVideo by Softron. Video is being directly outputted from a Black Magic UltraStudio Mini Monitor to a HDTV running at 25fps. Now I need to run graphics over the video, and wanting to overly at a different frame-rate, a much higher frame-rate for a smoother result (50fps). What will I need to achieve this? Or is this just plain ridiculousI know its best to keep all frame-rates the same, but 25fps interlaced is not the best considering I am working in different resolutions.
If this cant be done, how can I convert all my SD clips to 50fps from 25fps without the cuts fades or lighting change messing up for mac.
Thanks for your help
Closed Thread
One similar thread is enough. https://forum.videohelp.com/threads/359960-Frame-rate-converter-that-does-not-disturb-c...08#post2278508
And this is not any video streaming.
if you double the frame rate must you double the bit rate...
By deadrats in forum Video ConversionReplies: 11Last Post: 8th Oct 2013, 20:17 -
How to change Frame rate?????
By Choey in forum Video ConversionReplies: 9Last Post: 29th Jun 2013, 01:23 -
What should slide show bit rate and frame rate be in video editor?
By johnharlin in forum Video ConversionReplies: 0Last Post: 11th Sep 2012, 21:00 -
MediaInfo: Frame Rate vs Original Frame Rate
By adalect in forum Video ConversionReplies: 1Last Post: 19th Aug 2012, 17:44 -
Frame rate
By eponarider1 in forum Newbie / General discussionsReplies: 13Last Post: 6th May 2012, 09:17
