I assume, you ment, you can encode using vfw (video for windows) encoders.I can encode using FOURCC of windows:
(FOURCC is simply short for "four character code" - an identifier for a video codec, compression format, color or pixel format used in media files.)
No, ffmpeg has no (and never had) an option to use vfw encoders (or decoders), I'm not even sure that mencoder still supports the usage of vfw encoders, haven't used vfw codecs for ages. (+ afaik. even if mencoder still supports it, one would still need to create a mcf-config-File using vfw2menc)and in ffmpeg is possible this, also with an older version? -
@ElHeggunte: afaik vfw2menc is needed (for the configuration) if you want to use a vfw encoder, if you want to use a vfw decoder it's general characteristics either need to be included in the internal or external codecs.conf infos.
That aside, the main point was, that ffmpeg doesn't support either vfw de- or encoding.
If you want to run a 2-pass encode, yes, otherwise, no,
since the encoder settings can be read directly from the Registry
Code:=>mencoder -ovc vfw -xvfwopts codec=pvmjpg30.dll xintro01.avs -o zzbinstmainscene.avi MEncoder Redxii-SVN-r36207-4.6.3 (C) 2000-2013 MPlayer Team Custom build by Redxii, http://smplayer.sourceforge.net Compiled against FFmpeg version N-52649-g6021615 Build date: Thu May 2 00:22:47 EDT 2013 181 audio & 390 video codecs success: format: 0 data: 0x0 - 0xa9 libavformat version 55.4.100 (internal) AVS file format detected. VIDEO: [YV12] 640x480 12bpp 30.000 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:38 fourcc:0x32315659 size:640x480 fps:30.000 ftime:=0.0333 Loading codec DLL: 'pvmjpg30.dll' Loaded DLL driver pvmjpg30.dll at 3b80000 HIC: 2853780 568 - 568 - 568 Compressor type: 63646976 Compressor subtype: 67706a6d Compressor flags: 0, version 50331660, ICM version: 260 Flags: ICCompressGetFormatSize ret: 68 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 ========================================================================== Opening video decoder: [raw] RAW Uncompressed Video Could not find matching colorspace - retrying with -vf scale... Opening video filter: [scale] Opening video filter: [flip] Movie-Aspect is undefined - no prescaling applied. [swscaler @ 01550440]using unscaled yuv420p -> bgr24 special converter Opening video filter: [expand] Expand: -1 x -1, -1 ; -1, osd: 0, aspect: 0.000000, round: 1 Starting compression: Input format: biSize 40 biWidth 640 biHeight 480 biPlanes 1 biBitCount 24 biCompression 0x0 ('') biSizeImage 921600 Output format: biSize 68 biWidth 640 biHeight 480 biPlanes 1 biBitCount 24 biCompression 0x47504a4d ('MJPG') biSizeImage 741376 Output format after query/begin: biSize 68 biWidth 640 biHeight 480 biPlanes 1 biBitCount 24 biCompression 0x47504a4d ('MJPG') biSizeImage 741376 Selected video codec: [rawyv12] vfm: raw (RAW YV12) ========================================================================== Writing header... ODML: vprp aspect is 4:3. Writing header... ODML: vprp aspect is 4:3. Pos: 2.8s 86f (100%) 13.22fps Trem: 0min 15mb A-V:0.000 [46773:0] Flushing video frames. Writing index... Writing header... ODML: vprp aspect is 4:3. Video stream: 46773.312 kbit/s (5846664 B/s) size: 16565548 bytes 2.833 secs 86 framesIncorrectthe main point was, that ffmpeg doesn't support either vfw de- or encoding
--- the main point is, the OP asks the wrong question in the wrong time
Ah, okay, I assumed that the OS wasn't Windows, so no Registry in scenario.since the encoder settings can be read directly from the Registry
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53 -
Encoding interlaced with Mencoder or ffmpeg
By bstewart in forum Video ConversionReplies: 9Last Post: 30th Jul 2013, 14:57 -
Trans-coding VfW proprietary video using FFMpeg/AVISynth (if ness.)
By mmatta in forum Video ConversionReplies: 3Last Post: 20th Jul 2012, 21:28 -
Need mencoder.exe and ffmpeg codecs
By swkenney in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2010, 20:41 -
FFMPEG MENCODER murder and encoding
By Tom2me in forum ffmpegX general discussionReplies: 1Last Post: 29th Jul 2010, 12:44
