I've been using AnyVideoConverter to convert both mkv and avi files to mpeg2 to use on an older DVD player. One problem I've run into is the ones with hardcoded subtitles are not showing in the mpeg2, no matter what the subtitle setting for the conversion (use VLC, Zoom Player Pro). Are they hidden somewhere that can be retrieved? Or is there another converter that will handle them?
Then they weren't 'hardcoded' which, by definition, means they were 'burned' into the video. They'd still be seen however you converted the video.
It's better to make selectable subs anyway. Extract the subs and use a program that can add them to the DVD . One such is AvsToDVD. Maybe they were embedded (different from 'hardcoded') and maybe AvsToDVD can extract them and make selectable DVD subs for you. Not sure, but you could ask in the main AvsToDVD thread.
Blu-Ray to MKV to Hardcoded Vid w/ Subs to MKV to PS3
By psionicsin in forum Newbie / General discussionsReplies: 19Last Post: 3rd Mar 2011, 07:07 -
Add hardcoded subs in a mkv file
By joost1 in forum SubtitleReplies: 9Last Post: 2nd Nov 2010, 17:54 -
Mkv 2 Divx 6.0 with hardcoded subs through Avisynth and FFMpeg
By a6point6 in forum Video ConversionReplies: 3Last Post: 31st May 2010, 07:40 -
Mkv to mp4 with hardcoded subs on Mac
By Mauserman in forum MacReplies: 3Last Post: 30th Aug 2009, 04:19 -
Problems converting mkv to avi properly. (subs)
By biogenesis in forum Video ConversionReplies: 14Last Post: 27th Apr 2009, 00:31
