I was using the excellent handbrake to convert from Mpeg2 to Mpeg 4 compression and from MPG to MP4 container. Then I discovered that my hardware DVD player didn't like mp4 containers!
I have since found out that my combi tv/dvd, dvd supports:
'.mpg', '.dat', '.vob' containers with mpeg1 / mpeg2 video compression, mpeg1/2/3 audio compression
or
'.avi' container with 'ms iso' or 'mpeg4' video compression, pcm/mp3 audio compression
I have then tried using Winff to transcode to '.avi' container and:
video compression 'MPEG4'
audio compression 'MP3'
But the DVD player turns its nose up at it saying it doesn't support it.![]()
What to do program can I use to get mpeg4 video compression, mp3 audio compression, inside an avi container.
Results 1 to 17 of 17
Convert to avi divx / xvid instead. Divx/xvid is so called mpeg-4 asp and works on most dvd players with divx support.
In winff try choose the avi dvd player preset.
I like to use the old xvid4psp 5 and use the avi hardware preset.
You could also use video to video converter, freemake video converter or the official divx converter. Choose dvd hardware, avi divx/xvid preset in the converters. -
Or just try burn your mpeg2 files directly. It might play them directly...if they aren't in HD.
Thanks for the reply, but Divx / xvid is no good as my DVD player doesn't support divx.
The official divx converter does not export files in avi containers.
I am unwilling to install Freemake video converter as I've seen reviews where people have said it installs 'extra apps' notwithstanding them having told it not to.
xvid4psp doesn't seem to be available from mainstream download sites. The developer site seems to require silverlight!
I have been using the original mpeg2 files, but I really like the compression of mpeg4 which shrinks the file size down to a quarter of the originals.
I've recently tried MPEG Streamclip which can create a avi container with the codecs I need but the file size is six times the size of what I started out with.
Doesn't seem possible to change the container without re-encoding the codecs within. For example:
Source
MPEG4 video ------------ re-encoding----- MPEG4 video
MP3 sound ----------------re-encoding----- MP3 sound
MP4 container------------ re-encoding ---- AVI container
I might be better buying blue ray hardware player as many of these seem able (according to pdf manuals) to play mp4/mkv files. -
MPEG4 (Part 2) = Divx = Xvid
MPEG4 (Part 10) = h.264 = AVC -- your player doesn't support this
Note that there are several different fourcc codes that can indicate MPEG 4 Part 2 video in an AVI file. DX50, DIVX, XVID, XVIX, etc. You're player may not recognize all those different fourcc codes. DX50 and XVID are most likely.
It does if you select the old Divx 5.0/6.0 mode (at least the last time I tried it, quite a while ago). -
divX converter is now version 10. Tried 'theatre' preset which mentions avi, divX, mp3 but outputs in a divx container (and I thought divX was a codec!).
Nowhere to specify output container type. divx converter is fast though and compresses well.
Nowhere to 'select the old Divx 5.0/6.0 mode'. -
The divx container is the same as AVI if you don't use any advanced Divx features (like menus, chapters, etc.). Even if you use the advanced features, most player will just ignore the extra "chunks". Just rename the file .AVI.
Divx 5 through 10 all use DX50 as the fourcc for their MPEG 4 Part 2 encodings. There's almost no changes in their MPEG 4 Part 2 encoder since Divx 6. Not much between 5 and 6. Divx 6-10 are all backward compatible with the Divx 5 decoder. Ie, the Divx 5 decoder can decompress any MPEG 4 part 2 video encoded by Divx 6 - 10.Last edited by jagabo; 4th Nov 2013 at 17:01.
I renamed the output container type. divx to .avi.
DVD hardware player says 'unsupported codec'. But they play ok on computer. If I call up info on a video file using VLC it states:
Stream 0:
Type: Video
Codec MPEG-4 Video (DX50)
Resolution: 720x548
Frame rate: 25
Stream 1
Type: Audio
Codec: MPEG Audio layer 1/2/3 (mpga)
Channels: Stereo
Sample rate: 48000 Hz
Bitrate : 192 kb/s
TV/DVD hardware combo player format spec is:
http://i840.photobucket.com/albums/zz328/MuxedIfIKnow/TVdvdCombo/Formats001_zps3e4a97f7.jpg
http://i840.photobucket.com/albums/zz328/MuxedIfIKnow/TVdvdCombo/Formats002_zps1431b4ae.jpg -
Do you have a file that does play on your DVD player? What is the fourcc in that file? Try changing the fourcc to match using Avi Fourcc Code Changer.
https://www.videohelp.com/tools/AVI-FourCC-Code-Changer -
Here below is the info from the mpg file that plays fine on the hardware DVD player. However it's an MPEG2 codec inside a mpg container so surely the fourCC of 'mpgv' would flag up an error if used with an MPEG4 codec inside a AVI container?
Stream 0
Type: video
Codec: MPEG-1/2 Video (mpgv)
Resolution: 720x576
Frame rate: 50
Stream 1
Type: Audio
Codec: MPEG Audio lays 1/2/3 (mpga)
Channels: Stereo
Bitrate: 320 kb/s
Maybe someone else already has a solution for the hardware player? It's a Toshiba 22DV501B 22-inch TV/dvd combi. -
We know it plays MPEG video in MPG containers. We need to find out what fourcc it supports for MPEG 4 ASP in an AVI container. It's doubtful it will play MPEG 2 video in an AVI container -- that's an unusual combination.
Could non adherence to a filename structure of 8.3 be causing the issue? Manual says 'squat' on file name structure.
I remember reading recently someone stating that many dvd players play "mpeg4", (xvid), but will refuse to play divx for legal reasons. Baldrick suggested to download xvid4psp version 5 and I would also suggest this. You can download it from this site very simply, just click on the hyperlinked xvid4psp text that you see anywhere in this thread, and it will take you to the download section. (be sure to get version 5 newest beta that is highlighted).
You can encode into xvid with a avi/hardware player profile, that may very well work on your player. Handbrake is one of the top tools, the only one I like better is xvid4psp, and I would suggest you try this one out before anything else. -
No I think I'll wimp out! I have discovered that I can output a RGB video signal from my old laptop (which I use as a video recorder) to the TV. So using the mighty VLC, and excellent Handbrake I can have the small file sizes on DVD+r discs and play them via my laptop to display on TV. Not perfect because I have no remote control over playback, and I have to have two devices running. But neatly avoids all finicky proprietary code in hardware players!
I don't fancy installing programs in general on windows machines. I kinda like to live by the mantra 'you're only one install away from a compromised OS'. Now where did put my last good drive image!?
Help with transcoding (Encore CS6)
By kjpolker in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Jan 2013, 21:30 -
Transcoding vs Encoding
By pcexpress-guy in forum Newbie / General discussionsReplies: 51Last Post: 24th Sep 2012, 23:11 -
Transcoding Software
By Prince Valiant in forum Video ConversionReplies: 4Last Post: 11th Sep 2010, 10:26 -
Transcoding and Adobe Encore
By pc1971 in forum Authoring (DVD)Replies: 1Last Post: 13th Jan 2010, 23:13 -
Keeping subtitles without transcoding
By bobo343 in forum SubtitleReplies: 6Last Post: 11th Jan 2010, 11:05
