Is it possible to record the microphone in AND sound out (speakers) at the same time? I know one and the other can be done at different times, but what about at the same time? The only workaround I have seen is by mixing the two in Windows 7 sound options. This works, but the downside is that the mic in ends up coming out of the speakers. If there were a way to silence that mic in coming out and still record mic in AND audio out. Is there a way?
Unless your recording device has more than one channel (L-R), you have to use a mixer as you have done. The hardware solution would be to add another recording channel with a second sound card or use a mic mixer to feed the sound card line out and the mic into the line in.
But with computers a software solution is always more sensible. I assume you have to record the speakers because your source is a stream, something like this program might be what you're looking for; give the free trial a spin. On the freeware side, you should be able to script something with FFMpeg and maybe with Graphedit too.
HELP? - Need to record and broadcast digital video simultaneously.
By mpalm887 in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2011, 06:39 -
How do I: Record Video, Audio from MIC, AND Audio playing from speakers?
By miimaster2 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 21:51 -
Feed and record simultaneously?
By nkordyjaka in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Oct 2010, 23:15 -
Record to tape AND flash simultaneously
By exon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 28th Aug 2010, 15:45 -
[Hauppauge PVR 150] Any Ways to Live-Record Mic Input AND Line-in Audio?
By darkarn in forum Capturing and VCRReplies: 0Last Post: 27th Jul 2010, 21:13
