so i'm viewing a music video from a website and decide to keep it. i don't want to go bother relearning all that rtmp stuff and whatnot. i don't want to screen capture it either since my connection speed is only DSL and its not perfect. so, with a little luck, i find the file in a temp folder. however, the file is locked.
1. i tried to rename it. it won't let me do that.
2. i tried the usual click-drag, release to copy it, but it won't let me do that either.
3. i tried to open via hex. it won't let me do that either.
4. if i close down the webpage, the file will be deleted. it is not recoverable via undelete apps. i tried that too.
its not a movie, its a 3.5 minute low quality music video.
so what do you do (to recover or copy) a file like this ? did i miss anything else ?
If you are using firefox you can use the addon downloadhelper and see if it will download for you.
ok, i searched and found a
https://addons.mozilla.org/en-US/firefox/addon/video-downloadhelper/
and clicked the [+ add to firefox] button .. it went through the installation process (I think) but i don't see the add-on feature. -
ok, i read a little more. i went to this site:
http://www.downloadhelper.net/welcome.php?version=4.9.21
i should see three colored circles when a potential file is d/l'able. but they are grayed. i used its test videos that should work, but the circles are still grayed out and no arrows are showing. -
I had the same issues that you are describing,i had to refresh and click on the links,quit and reload and fiddle with the settings and finally got the links to work.
nevermind. it seems to be working. actually, the video from that website is recording, too.
i still don't have an answer to the locked file or file in use issue.
but at least this method works, thank you for your help!
How to download videos off certain websites?
By dbanimal in forum Video Streaming DownloadingReplies: 22Last Post: 25th Apr 2013, 11:24 -
Most Compatible Format for Websites
By ofpeb in forum Video Streaming DownloadingReplies: 11Last Post: 5th Dec 2011, 10:50 -
Locked MKV files, Multiple Instances of Explorer, PC Lag
By pushkin69 in forum Software PlayingReplies: 3Last Post: 9th Nov 2011, 22:22 -
Downloading Videos From Websites (Please Help!)
By LegendaryLero in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2011, 06:42 -
is it possible to transfer ranks between websites?
By lana2000 in forum Off topicReplies: 6Last Post: 3rd May 2009, 23:49
