A odd thing is, that if I download the Video from Youtube, the size is bigger than the one I uploaded and the quality worse, but not that worse as in the youtube flash player.
Youtube switched the wrapper from mkv to mp4, could the size and the quality loss be related to this ? If yes, shouldn´t I upload it as mp4 ?
Results 31 to 48 of 48
Youtube re-encodes everything, it doesn't just switch the wrapper . You always incur quality loss regardless of what you upload, regardless of what wrapper
The youtube player uses nearest neighbor for scaling and point resized upscaled chroma . Translation: it uses the lowest quality resizing and RGB display methods . It will always look worse than the exact same video played locally in a regular software media player (especially color borders like reds will look very "blocky") -
Does YouTube have any trouble with 16:10, because if I look back, I have Videos which are sharp as hell:https://www.youtube.com/watch?v=1aPsw1Q9iCU
looks like it is 16:10 related:
http://www.youtube.com/watch?v=rnF4VIQk2RU
Damn Youtube. -
Did you upscale one but not the other ?
This one is 1920x1080 , looks like it was recorded at 1920x0180
What about the other one ? 1728x1080 . What was it recorded at? You said you upscaled it in the 1st post. "double the respolution of the video (resize)" . That would explain everything
https://www.youtube.com/watch?v=vdt_l6vtmcs -
looks nice- Recorded at 1920x1080 and encoded with same resolution: https://www.youtube.com/watch?v=1aPsw1Q9iCU
looks blurry - Recorded at 1920x1200 and encoded with same resolution: https://www.youtube.com/watch?v=vdt_l6vtmcs
looks blurry - Recorded at 1920x1200 and encoded to 3840x2400: https://www.youtube.com/watch?v=YMzyZmKsTxk
looks good - Recorded at 1920x1200 and cut to 1920x1080: http://www.youtube.com/watch?v=rnF4VIQk2RU -
When I download the "1080p" version, this was scaled and re-encoded to 1728x1080, so it will look worse .looks blurry - Recorded at 1920x1200 and encoded with same resolution: https://www.youtube.com/watch?v=vdt_l6vtmcs
Any scaling will make it look worse. Even scaling done by the player (YT is 16:9 display , so anything wider or narrower will be letterboxed or pillarboxed) -
But it is still 16:10 ? You get black bars on 16:9 and if I download it says 1920x1200, too.
and yes, I´m sure I uploaded it as 1920x1200, this is the file I uploaded: http://www.mediafire.com/download/jn8nhapm8d8o11v/FTB-Server_erstellen_plugins_exact-s...00_x264vfw.mkvLast edited by Slind; 2nd Nov 2013 at 19:20.
I downloaded it via. the Backend. I now tried to download it with jdownloader 2 but I only get the 720p file.
Do you know something which, could make a 16:10 screen a 16:9 screen for video captures ?
Maybe something that adds a small blackscreen and setzt the monitor resolution to 1920x1080 or so? -
Never heard of Backend . Same with jdownloader 720p version only . IDM got the 1728x1080 versionI downloaded it via. the Backend. I now tried to download it with jdownloader 2 but I only get the 720p file.
YT keeps on changing things, and it takes a while for the downloading software to keep up
Not sure, Some graphics drivers / monitor combos might be able to display it like that, but 1:1 pixel mapping is always the best (your display will look worse if it's not 1:1 )Do you know something which, could make a 16:10 screen a 16:9 screen for video captures ?
Scaling it yourself and pillarboxing it yourself give you control over the algorithm used (higher quality) than if you left it to youtube. Or you can crop it yourself
Or you can set your apps to be windowed and record in a windowed mode -
yeah I was thinking about only using the 16:9 part of the monitor like if you watch a 16:9 movie. So the rest stays black, not used. I just tried to download the upscaled one and only get the 720p, too.
What do you think, would it work if I warp the video to 16:9 or should I go for crop or selfmade black bars better ? -
crop, do not resize (warp), you are working with 1pixel wide letters, yo have to record and export square pixel 1:1,
if you frame serve, project properties of your project are important, not clip properties, frame server is serving project properties, so if you have clip 16:10 in Premiere and project is set to 16:9, Premiere does resize to 16:9 while frame serving, you do not want that. I did something similar having project properties in NLE set to size of the clip and I did cropping (or padding) in Avisynth to have exactly 16:9 (either 1920x1080 or 1280x720) to prevent YouTube do anything weird to video. -
Is there any point why i shouldn´t use the .avi from premiere and wrap it with audio into a mkv instead of using the .264 and wrap it ?
How much and what type of editing are you doing? If it's just basic "cuts" as you described, you can do it with MeGUI. No need for another program for editing.
Are you aware of MeGUI's AVS Cutter under the Tools menu? Open the original video, index it and extract the audio, create a script for encoding and save it, then open the script with the AVS Cutter and use the preview to add your cuts to the script. MeGUI will then encode only the bits you want (effectively editing while encoding). The AVS Cutter can save a "cuts file' in order to re-encode the audio the same way, or you could use the Audio Cutter under the Tools menu if you don't want to re-encode it.
If it's just simple editing you're doing, that's the way I'd do it (well I do so regularly). Once MeGUI has encoded the video and re-encoded or split/rejoined the audio, you could then open the audio with another program to apply whatever effects you want, re-save it, then manually mux the modified version into the final output MKV (file).
If the original file is an AVI, I don't think MeGUI can extract the audio from it (although it'll use a script to re-encode it). If you want the original audio stream to work with, you'd need to demux it from an AVI manually, or remux the original AVI as an MKV then open the MKV with MeGUI for encoding.Last edited by hello_hello; 3rd Nov 2013 at 07:16.
ok, I confused you again in previous post, you are not using dmfs, although cropping or padding in Avisynth is easy and trusted
you encode within Premiere with x264vfw,... , to that question above, I'd say it entirely matters what youtube likes or dislikes, you have to check it out if it treats differently ...
DebugMode Frameserver causing problems in Premiere Pro CS6
By koberulz in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2013, 22:08 -
Premiere 6.5 + Debugmode frameserver work on Windows7
By pchan in forum EditingReplies: 1Last Post: 29th Aug 2012, 08:01 -
Premiere CS5.5 and DebugMode Frameserver - not rendering keyframes?
By ohcomeon in forum EditingReplies: 1Last Post: 14th Jul 2011, 11:52 -
Frameserver for Premiere Pro cs4 64 bit
By helionfilm in forum Video ConversionReplies: 3Last Post: 6th May 2011, 08:13 -
Adding command line options for mkvmerge in MeGUI
By chiaotzu in forum Video ConversionReplies: 1Last Post: 14th Nov 2010, 23:33
