Hi guys, its been a while since I've been here. Hope you are all well.
I have a problem that has started occurring only over the last few days.
I get stuttery playback of avi files. Whether they are dvd rip or Blue ray rips, the files play fine from an external drive but stutter when played back from my laptop's hard drive.
My laptop is running Windows 8.
Can any wise member Videohelp me out?
Peace
“He who makes a beast of himself gets rid of the pain of being a man.”
The basic info given would indicate a problem with the hard drive, or throughput.
Copy a problematic file from the hard drive to a different drive. Test. Report results.
Assuming it copies and plays fine, do a defrag and check for errors. If it does not, copy a new file to each drive from an independent third source. Repeat test and report procedure.
Assuming it is the hard drive listed in your profile, it is very old and likely dying. Prepare to replace, however in that box the expense is hard to justify.
Since it is extremely unlikely that the listed box is running Windows 8, then more information is required. Accurate information will lead to accurate answers. -
I'm staying out of this because I have no familiarity with Win 8, but I do want to warn you that if your laptop hard drive is an SSD, you CANNOT UNDER ANY CIRCUMSTANCES do a defrag of it. Well, the OS will hopefully warn you not to do it, but doing so anyway on an SSD may damage it or shorten its lifespan.
You should state what program(s) you are using to play AVI files. -
Hi all thanks for the interest. The computer in question actually belongs to my mother.
I am using VLC to play files.“He who makes a beast of himself gets rid of the pain of being a man.” -
I have a "computer" as well. I have several. We'll let you guess what I have if you'll let us keep guessing which "computer" you're using. I have some "external drives", too. You'll have to guess about those as well.
You say you have a newer Windows, but your profile sez you have XP on a Celeron machine that appears to be a laptop. You'll get better advice if you give us more information.Last edited by sanlyn; 20th Mar 2014 at 06:00.
Run chkdsk upon the internal HDD.
If it detects some bad sectors, then it's time to start thinking about a replacement. -
With the wealth of additional supplied information, I can quite confidently state my analysis:
There is something wrong.
Maybe the OP can get his Mommy to make any future posts and we might get something useful accomplished.
Problems with playback on PotPlayer
By TheGreeneYonder in forum Software PlayingReplies: 1Last Post: 4th Mar 2013, 22:20 -
problems with vlc playback
By 19sac65 in forum Software PlayingReplies: 2Last Post: 11th Oct 2012, 12:21 -
Playback problems
By erica12 in forum Newbie / General discussionsReplies: 7Last Post: 16th Feb 2012, 19:33 -
Full Blu-Ray Rip on HardDrive Stutters on Playback
By skywalka in forum Blu-ray RippingReplies: 0Last Post: 27th Jul 2011, 00:07 -
HD Playback problems (and a few other questions)
By borges_toto in forum Software PlayingReplies: 6Last Post: 9th Apr 2009, 11:01
