Closed Thread
    Oct 2013
    Jakarta
    So I have this MP4 file and it cannot be detected when I browsed my usb drive through my TV but when I chaned the extension, my TV detects it but once I try to play the file, it failed.
    My question is, how am I suppose to play it on my TV through usb drive?
    Thanks in advance.
  2. Member Cornucopia's Avatar
    Back up a bit and look at the file with MediaInfo. Don't start just "changing extensions". The extension is there to tell the player(s) what kind of container the file is.
    Use mediainfo's output to determine WHAT the container actually is and then change the extension back to that container name. Then, if your TV/player doesn't recognize or see the file, you know that what you have to do is CONVERT the file, aka re-encode it, or re-wrap it in a different container. Which way would be determined by whether your TV/Player(s) support the existing codec (re-wrap) or not (re-encode).
    Oct 2013
    Jakarta
    Here's what MediaInfo says:
    General
    Complete name                            : D:\Monsters University (2013) [1080p]\Monsters.University.2013.1080p.BluRay.x264.YIFY.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom
    File size                                : 1.64 GiB
    Duration                                 : 1h 43mn
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 2 268 Kbps
    Encoded date                             : UTC 2013-10-11 04:36:08
    Tagged date                              : UTC 2013-10-11 04:36:08
    Video
    Format profile                           : High@L4.1
    Format settings, ReFrames                : 4 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Duration                                 : 1h 43mn
    Bit rate                                 : 2 172 Kbps
    Maximum bit rate                         : 16.0 Mbps
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Bits/(Pixel*Frame)                       : 0.044
    Stream size                              : 1.57 GiB (96%)
    Writing library                          : x264 core 138 r2 9e941d1
    Encoding settings                        : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=2172 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=31250 / vbv_bufsize=31250 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
    Tagged date                              : UTC 2013-10-11 04:36:21
    Color primaries                          : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 1h 43mn
    Bit rate mode                            : Variable
    Bit rate                                 : 93.6 Kbps
    Maximum bit rate                         : 101 Kbps
    Channel count                            : 2 channels
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 KHz
    Stream size                              : 69.5 MiB (4%)
    Language                                 : English
    Encoded date                             : UTC 2013-10-11 04:36:20
    What should I do next?
    Thanks.
  4. Member Cornucopia's Avatar
    Read the TV's manual and see what formats (both CONTAINER and CODEC, and possibly PROFILE) it supports. Then follow the remainder of my suggestion...
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Buy Monsters University instead of downloading warez. Then can you rip it to mp4 with settings for your tv with for example handbrake.
    https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
