Im trying to convert an MP4 file into an MPEG so I can use it in TMPGEnc DVD AUTHOUR to produce a DVD that will play on a standard DVD player. I have tried using TOTAL VIDEO CONVERTER but it has converted the MP4 file into TWO halves. I cannot find any setting in the program that makes this SPLIT happen. The MP4 file is 275MB and lasts around an hour.
Can anyone recommend a good converter that will simply convert the MP4 file into one MPEG file that is able to be opened in TMPGEnc DVD Authour.
efiste2: You could also use Freemake Video Converter to take the .mp4 file and convert it to a DVD for you or an .mpeg2 file that should be DVD compliant that your Tmpgenc DVD Author will like. I have to caution you though if you chose Freemake Video Converter be very wary on the install as you can end up with Toolbars and other stuff you probably don't want on your computer. I would try the AVStoDVD first to see if it can get the job done.
Plain English Guide to MP4Box and Repacking MKV-MP4, MP4-MP4 (M4V).
By raregrit in forum Video ConversionReplies: 3Last Post: 8th Jul 2013, 13:52 -
SUPER converter: difference between MP4 file and Android (MP4)?
By mindstormer in forum Video ConversionReplies: 12Last Post: 30th Jan 2013, 06:15 -
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 14:36 -
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 20:46 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53
