Hello, dear all.
As the title said: " How to Join 2 or More SRT files to Create an *.IDX subtitle one?"
My goal is to have 2, 3 or more subtitles in srt format and put all them "together", but into IDX format.
PS: Usually I use Subtitle Edit to convert srt into idx. But, it's possible do it with more than 1 srt subtitle to IDX format using such program?
Thanks for helping.
Best regards.
devil (johner)
Open subtitle edit and click on tools/join subtitles.
Hello.
My goal it to add one or more languages stream(s) to an already existing "idx" file.
Similar the program below, but the opposite instead:
---> http://zuggy.wz.cz/ ( VobSubStrip )
Subtitle Edit can do it? Other programs can do it?
Thanks for your advice.
I guess I could find some ways to do it. See:
1) Convert each srt file into sub/idx using some programs listed below:
---> https://www.videohelp.com/tools/Subtitle-Edit
---> https://www.videohelp.com/tools/SubtitleCreator
---> https://www.videohelp.com/tools/Txt2VobSub
2) Mux all these sub/idx files into only one using VobsubMuxer:
--> http://www.trustfm.net/divx/SoftwareVobsubMuxer.php
Apparently this method works. Need more testing. Maybe we can do it using other programs and methods too.
PS: to strip languages streams fromsub/idx files we can use the program below:
Some more tips and advices about the subject are welcome.
Thanks.
vobsubmux and vobsubstrip mirrors:
https://www.videohelp.com/tools/VobSub#download
I wont add them as separate software pages.
MKVMerge GUI: How to Join two AVI with two SRT files (CD1 - CD2)
By Joujouba in forum EditingReplies: 1Last Post: 29th Aug 2013, 01:07 -
Convert .sub, .idx to .srt subtitles?
By Ryu69 in forum Video ConversionReplies: 17Last Post: 9th Jul 2011, 05:23 -
converting sub/idx to srt
By scarlac in forum DVD RippingReplies: 3Last Post: 9th Dec 2009, 08:26 -
How can Icreate 1 idx/sub with several srt?
By moryjingelbert in forum SubtitleReplies: 1Last Post: 15th Feb 2009, 15:42 -
IDX/SUB to SRT
By anirban in forum SubtitleReplies: 12Last Post: 5th Dec 2008, 22:05
