I have several Micro MV tapes but no camera. The video contains precious vision. Is it possible that there is some way that I can Capture the footage from these tapes please? Perhaps there is a carrier similar to the one used to play VHS/C tapes.
Thanks for any help.
Results 1 to 11 of 11
Nope,you need either a camera or reader,no way around that.
Thanks johnso, as I expected but can you explain what the "reader" is please. Thanks
@OP, johns0 was referring to some software or hardware that can read the tape. However, Sony was the only manufacturer and they only made camcorders, never readers. If your footage hasn't even been captured yet (and so are still only on the tape and not in file format), you are screwed unless you get a MicroMV camera (your ONLY option). Start scouring ebay, etc. Too bad, because once in file format, the encoding is MPEG2 (in, IIRC, TS streams @ 12Mbps), which could be fairly easily edited, etc. with modern softs.
Scott -
There were readers made for the 8mm but wasn't sure of other camcorders.By reader i mean a tape playing device similar to a vcr.
I figured. I know of reader/editor decks for: the VHS family, the 8mm family, the Beta family, the DV family. There was NOT one made for MicroMV. It was, by all accounts, a total loss for Sony.
Scott -
We have a camera for converting tapes for clients. We get maybe 1 project per year, for this. It's a REAL nuisance format to work with. Just send something like this to a service. The DIY method isn't ideal here, especially since most cameras are in such poor shape. It's nothing like VHS-C, and closer to 8mm with ever more quirks.
I would recommend lordsmurfs service.
I'm not sure that we can. The camera is NTSC. This person is in Australia (PAL). I don't remember if the cams can play NTSC and PAL, or only one format. I don't have a tape to test.
A good and complete cameras runs around $300. Sure, there are cheaper ones at eBay ($150-200), but good luck with that. It reminds me of Hi8 cams and Panasonic S-VHS VCRs, in this way.
Paying a service should be half that. Hence the advice. Few people have more than 10 MicroMV tapes.Last edited by lordsmurf; 30th Oct 2013 at 22:12.
Convert all MiniDV tapes to computer and say good bye to those tapes
By iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 00:01 -
Damaged micro SD Card
By BLSAMPLES in forum ComputerReplies: 7Last Post: 6th Mar 2013, 20:49 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 19:53 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 20:36 -
Sony Micro MV camera?
By lordsmurf in forum Capturing and VCRReplies: 2Last Post: 21st Mar 2010, 18:38
