I got two svcd movies and they both have a sample, so I try to open up the sample and it wont open in tmpgenc and it states: *cannot open or unsupported*, i tried the other sample that came with the movie and it said the same thing! I was wondering what did I do wrong and why wont it open? also, could it be also the fact that when they make the sample mpeg file may not be mpeg2 file as the movie? please reply thnx
I just had the same problem....be sure that you have teh MPEG2 Codec loaded (Check this site to the left under tools) and you may have to load the VBrun file, after I loaded both these I had no problems with loading MPEG2 (SVCD) into TMPGEnc. Just check under the tools section to the left, you can also find these on Stinky's site, click on the MMC Reg Tools to the left under the tools section.
Bud
XVID/mp3 file wont open in TMPGENc express
By efiste2 in forum Video ConversionReplies: 5Last Post: 14th Jan 2010, 17:16 -
Help the prgramme wont open!!
By amber123 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 23rd Apr 2009, 07:51 -
Sony vegas pro 8.0 wont open my files.
By Blake_t in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2008, 11:44 -
Can't open older TMPGEnc DVD Author files in latest version
By steelborn in forum Authoring (DVD)Replies: 1Last Post: 19th Feb 2008, 14:55 -
Cannot open wav files in Tmpgenc
By deadlycow in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2007, 03:54
