I'm writing a script to automate the muxing of .mkv files to .m2ts for compatibility with my Windows Media Center set up. Unfortunately, I can't seem to get tsMuxeR to work with the .meta file that my script outputs. The crazy thing is the files are exactly the same.
I originally thought there might be an issue with the carriage returns in my .meta file, so I adjusted the output and it's still not working. I even compared my two actual files with a file comparison software and it can't tell them apart. I have no idea why it's not working. Does anyone here have any experience with this?
Thanks!
My .meta file:
tsMuxeRGUI .meta file:Code:MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 V_MPEG4/ISO/AVC, "T:\downloads-completed\tv\Eastbound.and.Down.S04E05.720p.HDTV.x264-KILLERS [PublicHD]\eastbound.and.down.s04e05.720p.hdtv.x264-killers.mkv", insertSEI, contSPS, track=1, lang=eng A_AC3, "T:\downloads-completed\tv\Eastbound.and.Down.S04E05.720p.HDTV.x264-KILLERS [PublicHD]\eastbound.and.down.s04e05.720p.hdtv.x264-killers.mkv", track=2, lang=und
Output with my meta file:Code:MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 V_MPEG4/ISO/AVC, "T:\downloads-completed\tv\Eastbound.and.Down.S04E05.720p.HDTV.x264-KILLERS [PublicHD]\eastbound.and.down.s04e05.720p.hdtv.x264-killers.mkv", insertSEI, contSPS, track=1, lang=eng A_AC3, "T:\downloads-completed\tv\Eastbound.and.Down.S04E05.720p.HDTV.x264-KILLERS [PublicHD]\eastbound.and.down.s04e05.720p.hdtv.x264-killers.mkv", track=2, lang=und
Output with meta file generated from TSMuxerGUICode:c:\>"C:\Program Files (x86)\TSMuxer\tsMuxeR.exe" "T:\downloads-completed\tv\Eastbound.and.Down.S04E05.720p.HDTV.x264-KILLERS [PublicHD]\eastbound.and.down.s04e05.720p.hdtv.x264-killers.meta" "T:\downloads-completed\tv\Eastbound.and.Down.S04E05.720p.HDTV.x264-KILLERS [PublicHD]\eastbound.and.down.s04e05.720p.hdtv.x264-killers.m2ts" Network Optix tsMuxeR. Version 1.12.11(b). www.networkoptix.com Invalid codec format: ÿ_M
Code:c:\>"C:\Program Files (x86)\TSMuxer\tsMuxeR.exe" "T:\downloads-completed\tv\Eastbound.and.Down.S04E05.720p.HDTV.x264-KILLERS [PublicHD]\eastbound.and.down.s04e05.720p.hdtv.x264-killers.meta" "T:\downloads-completed\tv\Eastbound.and.Down.S04E05.720p.HDTV.x264-KILLERS [PublicHD]\eastbound.and.down.s04e05.720p.hdtv.x264-killers.m2ts" Network Optix tsMuxeR. Version 1.12.11(b). www.networkoptix.com Decoding H264 stream (track 1): Profile: High@4.1 Resolution: 1280:720p Frame rate: 23.976 H.264 muxing fps is not set. Get fps from stream. Value: 23.976 0.1% complete H264 bitstream changed: insert nal unit delimiters H264 bitstream changed: insert pict timing and buffering period SEI units Decoding AC3 stream (track 2): Bitrate: 384Kbps Sample Rate: 48KHz Channels: 5.1 B-pyramid level 1 detected. Shift DTS to 2 frames H264 bitstream changed: insert SPS/PPS units 98.9% complete Processed 39409 video frames 100.0% complete Mux successful complete. Muxing time: 12 sec
Can't you just install an MKV reader/splitter to play the MKV files with WMC?
http://www.groovypost.com/howto/howto/enable-mkv-windows-media-center/ -
Unicode vs. UTF-16 vs. UTF-8 vs. ASCII/ANSI problem? Check & see whether they are the same in a hex editor.
File permissions problem?
...strange...
TSMuxer crashing error code -3 TSMuxer GUI
By petermg in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Nov 2012, 16:21 -
Ffmpeg meta data fails to write UTF-8 and screws up files?
By burzum793 in forum AudioReplies: 0Last Post: 22nd Nov 2012, 06:36 -
Help me automating demux-remux dual audio files...
By CactusMan in forum Newbie / General discussionsReplies: 8Last Post: 6th Jan 2012, 21:59 -
tsmuxer and SUP files
By VTwrekker in forum Blu-ray RippingReplies: 2Last Post: 13th Feb 2011, 20:09 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 05:57
