It seems that my computer(windows8) have been occupied too much and there's a warning keeping coming out to disturb me.
Completely went crazy by this question. ok, what's the best way to stop the stupid hints?
Results 1 to 9 of 9
Fix the low space problem instead of the warning.
There's not much to do but then I can't do much anyway. -
Post your computer specs. Number of hdd, their size, what you have loaded taking so much space or what you are running that needs a lot of temp space.
Probably just spammers...Why join a VIDEO forum and ask for computer problems?
Defragging won't help. You should have at LEAST as much HDD space free as you have RAM, depending on your hardware, probably more for Windows to function properly.
Google is your Friend -
If this is a bought system it may be complaining about the restore os partition ... Im seeing way too many new systems coming out where the restore os partition is not being flagged as hidden so the os see's the drive (partition) as being full and flags a warning to free up space.
If this be the case then ignore the warning. -
Fellow posters you may want to save your effort unless the op proves himself to be legit.
Please take note of Baldrick's comment #5. What you don't see is that 3 new posters signed up within a very short time on the same day and the 3rd suspiciously linked to software. I don't know if #3 was banned since his only post was removed nor do I know if any one of the 3 was sincere but suffice it to say none of them have come back to post again. Time should tell.There's not much to do but then I can't do much anyway. -
Don't forget to empty the recycling bin after deleting files or set the recycling bin to remove files immediately when deleted. (usually not a good idea) This goes for Mac's as well as PC's.
removing annoying low space popups ?
By vhelp in forum ComputerReplies: 3Last Post: 22nd May 2013, 22:28 -
iPod Touch - trying to update to iOS 6 but hdd space too low
By vhelp in forum ComputerReplies: 5Last Post: 3rd Dec 2012, 21:27 -
converting movie to HD but low space format
By shahzadashraf30 in forum Video ConversionReplies: 7Last Post: 23rd Aug 2011, 05:32 -
A way to make the "Low Disk Space" warning go away?
By Xylob the Destroyer in forum ComputerReplies: 12Last Post: 21st Apr 2009, 17:27 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29
