Hi
considering my source is: https://dl.dropboxusercontent.com/u/39871584/C0020.mxf
Please go to my dropbox (user: mrocchini@email.it pass: centrale, folder: public) and download ffmpeg.exe / ffmbc.exe
so please do
1) ffmbc -i c0020.mxf -vcodec mjpeg -pix_fmt yuvj422p -sameq -vf colormatrix=bt709:bt601 -vtag MJPG -an 1ffmbc.avi
2) ffmpeg -i c0020.mxf -vcodec mjpeg -pix_fmt yuv422p -q:v 0 -vf colormatrix=bt709:bt601 -vtag MJPG -an 2ffmpeg.avi
3) ffmpeg -i c0020.mxf -vcodec mpeg2video -pix_fmt yuv422p -g 0 -q:v 0 -an -flags +ilme+ildct -alternate_scan 1 -top 1 3crocodileMPEG2.avi
1 and 2 are mjpeg
3 are mpeg2Iframe
What is the best result: 1, 2 or 3?
ps: add or remove colormatrix bt conversion depending on your monitor
Seems to me 1 (ffmbc) is the best clean.
psps: as decoder I use ffdshow (mpegINavi/mjpg)
There isn't a "best". It's a matter of personal preference. Choose which you prefer, which fits your desired usage, or by file size.
Google is your Friend -
No, it does not depend on your monitor but on the resolution being used.
BT.709 is for HD (> 1024x576) whilst BT.601 is used for SD.
http://en.wikipedia.org/wiki/Rec._709
Your monitor and your video drivers must be correctly set to accept both. -
At this point, I would think that your preference would be determined by target device/system compatibility requirements...
Scott -
marcorocchini, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
I can't use Arcsoft Video Decoder in MPC
By Lincoln Burrows in forum Software PlayingReplies: 1Last Post: 18th Jan 2012, 11:47 -
Which is the best video player/decoder for PC?
By Marione in forum Software PlayingReplies: 8Last Post: 26th Nov 2010, 13:31 -
newbie question in dv video decoder
By pcuser82 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Mar 2010, 23:42 -
Video Decoder info required. Thanks.
By seymoria in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2008, 00:02 -
Any Video Decoder for Hauppauge TV card? Thanks.
By seymoria in forum Capturing and VCRReplies: 2Last Post: 23rd Dec 2008, 11:14
