everything is fine with reencoding but subtitles are not visible anywhere VLC and BLu Ray player
menu shows about 20 languages but none of them are working
how i can fix that?
Closed Thread
Results 1 to 14 of 14
Geez, you want to start over again and this time explain what-all you did?
What's the source? What did you use to decrypt? Did it work after decrypting? What program did you use to reencode? And you made sure to get the subs into that reencode?
If it's BD to BD, have you tried BD-Rebuilder yet?
as i said everything is fine but after reencode subitles arent visible there are about 20 languages but none of them are able to turn on
original source subs are working but after reencode no sub
i will try dvdfab 9 reecode as alternative method and check if this is source fault.
original source is ~39GB rebuilder workd fine i am using always full disc encoding but this is 1st time ever when subtitles arent visible in any language.
dvdfab is doin nothing after 17% complete reencoding too just ideling
i also put manually put sustitles SRT and its working
well BD Rebuilder i got only INF log i dont have reecoding log
but i am thinking bout 2 ways where 1 is already working
i mean 1st is manually replace subtitle by SRT and replace M2ts file and as i said its working
2nd redownload only movie file m2ts again and reencode again
but
when i was trying to encode using DVDFAB subtitles was visible [it was just 5Gb file ] but that tool was ideling @17% and stopped encoding
was trying also unknown BD Cloner 4 but it says error failed coded so deleted everything.
[Status]
LABEL=WHITE.HOUSE.DOWN.2013.CEE.BLURAY.1080P.AVC.D TSHD.MA5.1.DIY-YOYO
VERSION=v0.44.16 (beta)
SOURCE_SIZE=43392856320
SOURCE_VIDEO_SIZE=43063056384
TARGET_SIZE=24641536000
REDUCTION=.564561322522221
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=-1
INSTANCES=1
DGDECNV=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
REBUILD_COMPLETE=1
COMPLETED=18
[00001]
AUDIO=1001000
PGS=11111111111111111111110
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=18876029665
RATE=13754
SPLITS=1
NSTART=27000000
NEND=408580470
NSIZE=18395068416
FLINK=0
MLINK=0
[00097]
AUDIO=1
PGS=
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=201183
SPLITS=1
NSTART=27000000
NEND=27045000
NSIZE=245760
FLINK=0
MLINK=0
[00098]
AUDIO=1
PGS=
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=593142
SPLITS=1
NSTART=27000000
NEND=27135000
NSIZE=724992
FLINK=0
MLINK=0
[00102]
AUDIO=
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=182410143
RATE=4723
SPLITS=1
NSTART=27000000
NEND=39924161
NSIZE=178728960
FLINK=0
MLINK=0
[00334]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=488790364
RATE=9715
SPLITS=1
NSTART=27000000
NEND=43410240
NSIZE=477345792
FLINK=0
MLINK=0
[00335]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=334459063
RATE=9709
SPLITS=1
NSTART=27000000
NEND=38220480
NSIZE=325699584
FLINK=0
MLINK=0
[00336]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=423142415
RATE=9683
SPLITS=1
NSTART=27000000
NEND=41218560
NSIZE=413380608
FLINK=0
MLINK=0
[00337]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=298024208
RATE=9645
SPLITS=1
NSTART=27000000
NEND=37061280
NSIZE=290174976
FLINK=0
MLINK=0
[00338]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=382295418
RATE=9635
SPLITS=1
NSTART=27000000
NEND=39924000
NSIZE=373106688
FLINK=0
MLINK=0
[00339]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=285901225
RATE=9669
SPLITS=1
NSTART=27000000
NEND=36627840
NSIZE=278974464
FLINK=0
MLINK=0
[00340]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=232449101
RATE=9689
SPLITS=1
NSTART=27000000
NEND=34809120
NSIZE=226639872
FLINK=0
MLINK=0
[00341]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=361122689
RATE=9734
SPLITS=1
NSTART=27000000
NEND=39070080
NSIZE=352487424
FLINK=0
MLINK=0
[00342]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=276116121
RATE=9778
SPLITS=1
NSTART=27000000
NEND=36191520
NSIZE=268922880
FLINK=0
MLINK=0
[00343]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=413648679
RATE=9692
SPLITS=1
NSTART=27000000
NEND=40901760
NSIZE=402868224
FLINK=0
MLINK=0
[00344]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=306217194
RATE=9655
SPLITS=1
NSTART=27000000
NEND=37314720
NSIZE=298641408
FLINK=0
MLINK=0
[00345]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=274572566
RATE=9637
SPLITS=1
NSTART=27000000
NEND=36267840
NSIZE=267472896
FLINK=0
MLINK=0
[00346]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=755378063
RATE=9687
SPLITS=1
NSTART=27000000
NEND=52358400
NSIZE=736505856
FLINK=0
MLINK=0
[00347]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=420384826
RATE=9704
SPLITS=1
NSTART=27000000
NEND=41090400
NSIZE=410093568
FLINK=0
MLINK=0
i am still undecided but at last i will try redownload main movie file again its 31GB and if last time reencode will b same [subtitles available but wont visible OSD] i will use mine own method adding from SRT.
anyway this is 1st time ever that i have something like this.
Also
if redownload and reencode will this time b working i ll also report it
Buy it instead of downloading warez crap.
https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
A good program to merge subtitles (not only white, and in italics)
By patryk8820 in forum SubtitleReplies: 2Last Post: 22nd Oct 2012, 23:40 -
Problem with the monitor: showing only white screen
By 1234567 in forum ComputerReplies: 0Last Post: 8th Aug 2010, 13:26 -
Need black background behind white subtitles Subtitle Workshop
By kinghlg in forum SubtitleReplies: 6Last Post: 13th Mar 2009, 12:18 -
Question why no subtitles using Fair Use Wizard on black& white movie
By jimdagys in forum SubtitleReplies: 0Last Post: 7th Mar 2009, 06:35 -
Create black background against white subtitles please?Achieved won't stick
By max2 in forum SubtitleReplies: 6Last Post: 12th Nov 2008, 14:09
