this is source 6 Mbps
http://www.sendspace.com/file/pt17eq
and this is 2.7 Mbps which was transcoded from above by YouTube
http://youtu.be/KwyjAPWVGAE
as you see file size is twice smaller and quality is not noticeable worse (best to check are details on tire)
I wonder how does YT transcode as I wasn't able to replicate the same effect on my PC
To get best quality of video uploaded to Youtube look here: https://support.google.com/youtube/answer/1722171?hl=en&ref_topic=2888648
Extraordinary claims require extraordinary evidence -Carl Sagan -
It's not often YT is "praised" for good quality.
They use a modified x264 build, and one "trick" is they throw away 1/2 the frames - Your source video is 720p50, but YT is 720p25. You can do the same thing with some GUI for x264 e.g. handbrake, ripbot, megui, xvid4psp, ...etc... dozens others
You can even get better quality, because you can use slower higher quality settings with multipass encoding. YT emphasis is on speed (they use lower quality, faster settings) so they can post videos up faster -
The youtube video is of lower quality. But there's no secret. Just use a decent h.264 encoder and the same lower bitrate. x264 can do better than youtube's encoding, even keeping the 50 fps frame rate.
yes, that's why I wanted some guidance because simply lowering bitrate got me worse quality / strong compression
You could use a batch file like this:
Then drag and drop your MP4 file onto the batch file. Change the path to x264.exe if you have it in a different location.Code:"C:\Program Files\x264\x264.exe" --preset=slow --pass=1 --bitrate=2550 --sar=1:1 --output %1.mkv %1 "C:\Program Files\x264\x264.exe" --preset=slow --pass=2 --bitrate=2550 --sar=1:1 --output %1.mkv %1
thanks, MediaCoder gave me good results, I have to work on some details but now I have 14 - 15 MB with no visible quality loss
MultiAVCHD transcode 4:3 --> 16:9?
By Ennio in forum Video ConversionReplies: 1Last Post: 24th Jun 2018, 08:16 -
Transcode while you are Downloading
By mreccentric in forum Video ConversionReplies: 9Last Post: 26th Oct 2013, 13:01 -
Encore 'can't transcode' file set to 'Don't Transcode', won't build ISO.
By koberulz in forum Authoring (DVD)Replies: 0Last Post: 5th Aug 2012, 13:18 -
transcode problem with Vidrop
By aerobat77 in forum DVD RippingReplies: 1Last Post: 15th Jan 2009, 18:19 -
Transcode A DivX
By Anakin in forum Video ConversionReplies: 4Last Post: 19th Nov 2008, 08:29
