Hi all !
I have a Toshiba SD-1300 DVD Player, he is working great on DVD & VCD.
I have a problem when playing SVCD, the Toshiba recognize the SVCD disc as a VCD disc (according to the DVD led's). it's playes the video fine but the audio is out of sync.
When I play the same SVCD Disc on other DVD (Hyundai 2020 - much cheaper DVD...) it plays fine both video and audio.
Did someone have this problem ? Do you think that the DVD Is broken ?
Thanks Guys !
Hi there,
I am having the exact same problem with the same DVD Player .... not happy. I am currently playing around with different settings. Works great with VCD's, but not with SVCD's. Have you made any progress?.
Regards,
Joe.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 09:40 -
how to play seamless loop svcd's
By markwest in forum Authoring (VCD/SVCD)Replies: 8Last Post: 11th Aug 2007, 14:06
