Results 61 to 73 of 73
So I did a search for "avidemux android preset" and very quickly found this:
https://help.ubuntu.com/community/AndroidVideoEncoding
That may be a ubuntu link but I don't see why it wouldn't work in the windows version of avidemux. I use avidemux or handbrake in linux and that's what I used to use in windows and the codec libraries are the same. And neither needs stupid codec packs. -
@ UnD3R0aTh: IF/WHEN you feel your problem has been solved,
please EDIT THE TITLE OF THIS THREAD ---
--- example: erase "Plz help, VP6A mkv only plays in avidemux!" and write
"[SOLVED] VP6A mkv only plays in avidemux".
From the forum rules <= click:
Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems. -
can you plz write a script for a similar but different set of files? thx
p.s. i removed -map 0:2 from previous script because it gave error, it did encode but the final file had no audio!
General
Unique ID : 181263954914433585490036751662689762813 (0x885E2AF8EC81907CBC8B6E63898F3DFD)
Complete name : *.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 274 MiB
Duration : 55mn 28s
Overall bit rate : 691 Kbps
Encoded date : UTC 2013-04-21 20:54:42
Writing application : mkvmerge v6.1.0 ('Old Devil') built on Mar 4 2013 09:10:42
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video #1
Format : VP6
Format profile : Heightened Sharpness
Codec ID : V_MS/VFW/FOURCC / VP6F
Codec ID/Hint : On2
Duration : 55mn 28s
Width : 660 pixels
Height : 600 pixels
Display aspect ratio : 1.100
Frame rate mode : Constant
Frame rate : 30.000 fps -
what?! xD
similar codec, different group of files, that has only one video stream! -
i set map to map 0:1, now it gives mp4 files containing audio only!
edit i think i figured it out, map 0:0 for video, map 0:1 for audio cheersLast edited by UnD3R0aTh; 8th Nov 2013 at 05:09.
guyz the file sizes i'm getting are big, how can i get equal or less sizes?
-b:v 500k
this means bitrate encoding for video stream is 500kb/s
filesize = bitrate * running time
So if you decrease bitrate by 1/2 (e.g. -b:v 250k), the video stream filesize will be reduced by 1/2 compared to if you had encoded with 500kb/s (note that doesn't include audio , because you have to add up both audio & video bitrates , plus accessory streams and container overhead)
There might be something else going on, it would be better if you posted a sample
Trying to edit .mkv with Avidemux..
By brawltimore in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2013, 09:04 -
Avidemux editing MKV
By hilltop in forum EditingReplies: 1Last Post: 25th Jul 2012, 13:06 -
Avidemux and mkv
By pooksahib in forum EditingReplies: 2Last Post: 1st Jun 2011, 23:50 -
VP6a encoding / video with alpha channel
By GRUMBLE in forum Video ConversionReplies: 2Last Post: 26th Aug 2010, 04:08 -
ogg in mkv with AVIDEMUX
By Kurgan71 in forum Video ConversionReplies: 4Last Post: 23rd Apr 2009, 03:51
