Is there a video editing program out there that allows for custom resolutions and bitrates?
I want to edit some old digital videos (early to late 90's mostly) who have different resolutions and bitrates. I need a video edit program that will allow for each individual video to be edited (cutting parts out of the video like bad takes and such) with the same resolution and bitrate intact in order to avoid messing up the aspect or getting a huge filesize due to a large bitrate when the video had a much smaller bitrate.
_____________________________
Thank God For Jesus Christ!!! -
Yes, many are. But the problem comes when choosing which codec to use, as some codecs require/allow only certain size combinations (the math that facilitates the efficiency in their compression must use block size multiples of 4, or 8, or 16, etc).
Also, there are STANDARDS, and they are there for a reason: to make it easier to view on common equipment. If you deviate from those standards, you set yourself up for difficulty in your efforts at playback (particularly on hardware/settop devices).
Much easier to use the standard size templates and just resize your video(s) to match. Yes, some quality may be lost, but not much more than the loss that you're going to encounter anyway since your are editing, processing & re-encoding.
If you don't want to "balloon" your filesize and want to maintain the same codec, use an editor that supports "Direct Stream Copy" and/or "Smart Rendering". Those are usually only available for CERTAIN codecs and when doing only CERTAIN basic kinds of processes (I-frame cuts being the main one).
Trying to Understand Video Resolutions
By KyleMadrid in forum Newbie / General discussionsReplies: 7Last Post: 3rd Feb 2013, 10:18 -
PS3 video resolutions MP4 & Xvid
By deadmeow in forum Media Center PC / MediaCentersReplies: 1Last Post: 16th Dec 2012, 04:50 -
Understanding video adapter resolutions
By GordonVCD in forum ComputerReplies: 7Last Post: 15th Jan 2011, 20:39 -
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 14:21 -
Custom Video Converstion Help 720p to custom 720p
By powerplyer in forum Video ConversionReplies: 5Last Post: 4th Jun 2009, 14:14
