Hi all, I've googled this problem and many posts are many years old so I thought I would ask here.I have mp4 file with sound off by approx 2 seconds. I am going to convert this to an avi file (have an old dvd player) is there a program that will allow me to re-sync this while converting or is it best to re-sync first then convert. Can you please suggest a program to re-sync. Many thanks for any help...
It doesn't matter so much when you adjust the audio sync, so it might depend on the program you're using for converting.
Even after converting the MP4 to AVI though, you can open the AVI with a program such as VirtualDub and adjust the audio delay (from the Audio/Interleaving menu). Then resave it as a new AVI after selecting "Video/Direct Stream Copy" from the top menu. That way, VirtualDub will just copy the video and not try to re-encode it (the audio uses Direct Stream Copy by default).
DVD Conversion Lip Sync Issues
By waykins in forum DVD RippingReplies: 4Last Post: 4th Jun 2011, 10:23 -
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 17:36 -
Media Player Classic Lip Sync
By rckowal in forum Software PlayingReplies: 2Last Post: 9th Jan 2011, 13:31 -
Formula for NTSC to PAL lip-sync
By macnab in forum Video ConversionReplies: 4Last Post: 11th Aug 2010, 11:16 -
dvdauthorgui bad lip sync problem
By prioryjim in forum Authoring (VCD/SVCD)Replies: 5Last Post: 2nd Dec 2009, 05:47
