Best way? Wiring or in editing?
Does going from an XLR mic (Sony ECM-66B) to my HV40 stereo jack with the Hosa cable (second link below) defeat the purpose of having a high end mic? Should I go into the HV40 in mono and duplicate audio tracks in Vegas Pro 11?
http://www.mediacollege.com/audio/connection/xlr-jack-stereo.html
http://www.ebay.com/itm/Hosa-XVM-115F-15-Foot-XLR-Female-to-3-5mm-TRS-Stereo-End-Cable...item33865ba282
The two items above are wired differently. I bought the second (Hosa) on ebay.
I'm doing voice - monologue and want the same on both channels.
Depends what the definition of the word inhale is. -
Kind of. That cable is a passive cable, doing nothing WRT impedance mismatch nor level adjustment, and only fudges the balanced to unbal connection. It will work, but not near optimal. Better (pro quality-wise) to get an active mixer/adapter/balun or just plug in the xlr and do the mono thing in post as you mentioned.
But who knows? You might be satisfied with it...
Recording 2 Wired mics with only 1 mic input...
By clarkkwgriswold in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 22nd Apr 2012, 16:51 -
XLR to 3.5mm shotgun mic
By Gerrysw in forum AudioReplies: 10Last Post: 30th Dec 2011, 17:36 -
3-channel xlr mic mixer with 3.5 mm camcorder?
By hurry in forum AudioReplies: 1Last Post: 21st Sep 2011, 09:40 -
Need mic input on camcorder
By loldmanjenkins in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 11th Dec 2010, 17:00 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46
