When i rip a film with a menu DVD Decrypter, then burn it, it will not play on VLC. It will play on Windows media player. I can see the menu and can click on it but it does not play. I unticked start from mmenu in VLC
is it the menu and can that be removed with dvd decrypter.?
The original will play on VLC when i click play in the menu.
I would appreciate if anyone could say why and what to do. i can play it on the TV standalone but I would like to understand.
it is my film which I bought and want to make backup
Results 1 to 30 of 37
Not enough information. So, you decrypted the entire film using DVD Decrypter in File Mode? Does it play from the hard drive in VLC? And how did you burn it to disc? IMGBurn, I hope? And this DVD, since it plays in your standalone, it's most likely a good DVD. Have you tried it in other software DVD players besides WMP, ones such as MPC-HC or MPC-BE?
Yes, you can decrypt just the movie using IFO Mode in DVD Decrypter. No menu.
And I'd attach no importance to a DVD not playing in VLC. I don't think it's a very good DVD player to begin with and don't use it. -
Yes
YesDoes it play from the hard drive in VLC?
BurnAwareAnd how did you burn it to disc? IMGBurn, I hope?
Seems soAnd this DVD, since it plays in your standalone, it's most likely a good DVD.
Do not have these
ThanksYes, you can decrypt just the movie using IFO Mode in DVD Decrypter. No menu.
I disagree I think its good and would like to have the disc play in itAnd I'd attach no importance to a DVD not playing in VLC. I don't think it's a very good DVD player to begin with and don't use it.
Thanks for your reply -
Download PGCEdit
load VIDEO_TS and CLOSE first pop up wizzard (looking for BOV's, you do not need that)
press "toggle trace mode" icon , top bar, second from the right (two arrows in blue circle)
now press "step" button (down on screen, left hand corner), keep pressing, .., this way you are actually navigating through DVD manually , keep pressing,.., when you get to your menu, you have to select some button that you will see on screen and press select ..., keep pressing "step" button again until you actually get to your title ..
if navigation is as you'd expect, DVD navigation is alright, and therefore there is a bug in VLC player ... -
A "first play" is a short video that plays before the main menu appears. First play commands control playing that video. For example, the person authoring the DVD may want to show the first play after the DVD is initially inserted in the player but not when the movie is over and the main menu is re-displayed.
Apparently it plays in everything but VLC Player. Right? Doesn't that tell you something? Anyway, until you've burned it using ImgBurn there's no point in me participating any further because I don't think it's been established the burning program isn't at fault. And I wasn't knocking VLC Player as a general file player, only as a DVD player. Like videobruger, PowerDVD is my 'reference' DVD player, although I do use MPC-HC/MPC-BE a lot. There are also a bunch I've never tried.
How to tell what to remove? There are two folders PGC 1 and PGC 2. One is 12 seconds and the other one and half hours. Is the short one the menu?Originally Posted by manono;2276357
Yes, you can decrypt just the movie using IFO Mode in [url=https://www.videohelp.com/tools/DVD-Decrypter -
How can i tell what pcg refers to the menu
Does DVD Decrypter choose its own folder? Anytime i change the path I get empty folder -
And the movie's length is one and a half hours, isn't it? Does that give you the answer to your question about how to get the movie without the menu? Neither is the menu.
You remove nothing. You get the movie without the menu. When you use DVD Decrypter in IFO Mode it automatically points to the longest PGC (title), not to a menu. -
it is not attitude, it is called "answer", ..., that is what they told me while I was learning English
DVD Decrypter last update 8 years ago
Please try DVDFab Decrypter or AnyDVD(21 days trial) -
Maybe. But in contrast to protection schemes where new ones are constantly developed the video codec used for a DVD has remained unchanged so there isn't the same need for a "modern" one.Shrink is way out of date too.
DVD Shrink may be old, but since it works with DVD files and folders that were already decrypted and copied onto a hard drive using other software, it is still a reasonably good tool to use for shoehorning dual layer DVD movies onto single layer DVDs. DVD Rebuilder Free is another tool that can be used for reducing the size of movies on dual layer DVDs so they will fit on single layer DVDs, but DVD Shrink is supposed to transcode a bit faster
DVD FAb Decrypter free tries to connect to internet. Does the paid version do that too?
almost all modern software will try to connect to an update server.
The only problem is that the free DVD decrypters that rip to a DVD structure and do not try to connect to the Internet are unable to deal with some forms of copy protection. ...so if you don't want to use DVD Fab HD Decrypter free, then you will have to live with the inability to copy some movies produced in the last 8 years or so.
VLC: Cannot return to DVD menu
By terrypin in forum Newbie / General discussionsReplies: 3Last Post: 1st Jul 2013, 16:49 -
menu transition sticks in VLC
By StrobeLightEpileptic in forum Authoring (DVD)Replies: 5Last Post: 21st Jun 2013, 13:57 -
how to get this to play on VLC
By A7med in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2011, 18:54 -
R-click context menu for VLC and WMP - not working
By terrypin in forum Newbie / General discussionsReplies: 0Last Post: 16th Nov 2010, 07:44 -
Subtitles removed but still in VLC's menu?
By Information in forum SubtitleReplies: 3Last Post: 25th May 2009, 13:31
