    Mar 2006
    Poland
    Hi
    I am using HDMI capture card with Monster-X software. I have 720p input signal and wants to capture in H.264 3 Mbps however this software has starting point at 6 Mbps (it would be great if someone could modify it). There is however option to select other encoder. Here are grabs from the software
    http://imgur.com/a/hrhGs
    I struggle with selecting this third option; it's just too many positions. Could you guide me what to select to have this going ?
    I can manage with encoder configuration however first I need this recording.
    You could ask : why don't you use other capture software ? answer is simple, I want sound recorded over HDMI and couldn't find suitable software that can open capturing video and audio over HDMI and record to H.264.
    Third option? The one with avi mux? Try mainconcept mp4 multiplexer and see if you can save as a mp4 file.
    Mar 2006
    Poland
    that's the one;
    it won't save to mp4 as you see there is no cointainer like than on the list
