Hello everyone!
Does anyone could tell me how to do it, if possible with a tutorial?
I've tried using TSmuxing, selecting both .m2ts files (respect movies, part 1 and part 2), M2TS muxing, it creates a big file (combines both sizes into one file), but just play the first part.
Have you tried mkvtoolnix / mkvmergegui ? Use the append function to join both m2ts files.
But the video and audio properties must be SAME or it wont work to join. -
Thanks for the answer... I'll try to append those. I'll be back with the results... thanks
I was with the TSmuxer opened, so I tried on it, and it works... thank you so much! Just an observation, you can't chose language or subtitle for the video that is appending (second part). Perfect... thanks
So, for who has the same problem, you open the TSmxer, add the first part of the video, then click join and select the second part of the video, select m2ts muxing, then click OK. That's it.
Burning a MKV to Blu Ray Disc
By bbren43 in forum MacReplies: 37Last Post: 23rd Jan 2015, 16:29 -
Handbrake: Blu-ray Disc to MKV Help! Video Stretching Issue!
By Mickey79 in forum Blu-ray RippingReplies: 3Last Post: 22nd Feb 2013, 12:01 -
Burn mkv/whatever to blu ray disc playable on Vizio Blu ray player?
By Eric1987 in forum Authoring (Blu-ray)Replies: 3Last Post: 1st Dec 2012, 21:41 -
how to rip a blu-ray movie to a blu-ray disc
By TURBOLENCIA in forum Blu-ray RippingReplies: 1Last Post: 25th Nov 2010, 16:40 -
Can you rip a blu ray file, make edits, and put it back onto the same disc?
By FatalX in forum Blu-ray RippingReplies: 6Last Post: 24th Apr 2010, 16:49
