Hi,
I have been searching the web for information but cannot find anything on the subject.
Does anyone know if it is possible to create reference MXF files, similar to Quicktime reference MOVs that can be created from FCP. I need to generate an MXF header that can link together separate essence files, M2V + multiple WAV audio files.
Also can you recommend software that can create these reference header files.
By definition, mxf is always self-contained. You may be looking for something like aaf.
SONY XDCAM HD422 .MXF file and... In Sync Blade 2.2
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 2nd Jun 2013, 00:20 -
Convert to MXF file with closed GOP every GOP?
By Gobblor in forum Video ConversionReplies: 0Last Post: 17th May 2012, 04:27 -
MKV Reference File
By coolguygwh11 in forum Video Streaming DownloadingReplies: 2Last Post: 16th May 2012, 14:41 -
MXF with JPEG2000 codec in Mainconcept Reference
By lord25 in forum Video ConversionReplies: 1Last Post: 3rd Nov 2009, 09:34 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00
