I have a linksys wrt54g v2 router. I want to upgrade to a ea4500 linksys. I am hard wired to my desktop & wireless for laptop & every now and then for the netflix on my tv. My question is will the newer one be faster for both or just the wireless?
Whether it is FASTER depends NOT ONLY on the router device, but on the devices attached to it AS WELL. It has Gigabit Ethernet (up to 1000Mbps) and 802.11N wireless. Like most Wireless N routers, it should have fallback to G, B & A, just like Gigabit Ethernet has fallback to 100 and 10.
So, if all your devices are 100Mbps wired and Wireless G, then it won't be any faster AT ALL. If, however, some devices have better specs than that (whether wired or wireless), the new device will allow THOSE devices to take advantage of the speed boost.
Remember, of course, that overall speed is governed most by the WEAKEST LINK, which usually is your Internet connection.
Scott -
My internet is 15 mbps download speed. My computer is 4gb ram also laptop is 4gb ram. Downloading i think is pretty good.I am thinking of adding a wired computer downstairs instead of going wireless. I just want to make sure router is up to it.
N router
By jyeh74 in forum Off topicReplies: 0Last Post: 30th Mar 2012, 21:35 -
Getting A New Router
By Tom Saurus in forum ComputerReplies: 17Last Post: 11th Nov 2011, 16:42 -
Recommend a router.
By Poppa_Meth in forum ComputerReplies: 7Last Post: 6th Mar 2011, 19:46 -
wireless router
By alintatoc in forum ComputerReplies: 6Last Post: 14th Feb 2010, 04:59 -
Possible router problems.....
By SE14man in forum Newbie / General discussionsReplies: 21Last Post: 25th May 2009, 22:05
