ffdshow opens your sample in the other thread as mpg2 in vdub for me
https://forum.videohelp.com/threads/359533-MPEG2-decoder?p=2274668
However, long GOP MPEG2 with b-frames in AVI has serious problems - you can get black/green frames, frames out of order. It's not possible to edit accurately without indexing. AVI not a suitable container for compression with b-frames . I-frame only MPEG2 won't have those issues (or any compression that is I-frame only) . The problem is AVI container does 1 frame in and out at a time, but temporal compression can reference foward and backward frames . This problem is not limited to long GOP MPEG2 (othr types of compression with b-frames as well in AVI container) -
but I think have a mpeg-2 I frame as source.
I import the .avi files in Speed Razor, previously I have set vidc.mpg2=ff_vfw.dll (with the ffshow installed and configured) otherwise Speed Razor can not import nothing.
But the deblocking image remains
FFDSHOW: can I do in ffdshow what I do with "-vcodec copy" in ffmpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 20th Oct 2013, 16:25 -
How to set ffdshow 64bit as defaul x264 decoder?
By xicudiz in forum Software PlayingReplies: 10Last Post: 9th Oct 2013, 07:16 -
5.1 audio decoder
By robinmishra in forum AudioReplies: 4Last Post: 24th May 2011, 18:22 -
FFDshow audio decoder level is way too low...
By MidnightMike in forum AudioReplies: 2Last Post: 4th Dec 2010, 00:34 -
AVI file and Video Decoder Configuration (ffdshow)
By mahogany in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2010, 18:14
