I'm using roxio easy cdcreator 5.o and trying to make a menu for my vcd...ive tried using an mpg still and a reagular image and a reg. mpg but it keeps telling me it has to be converted first ? Converted to what and how do I do it?
Thanks all
Is it telling you that the mpeg you are adding is not fully compliant, and would need to be converted before use.
VCD mpeg's must be correct before you attempt to use them in burning programs.
TMPGEnc > load > template
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Want to use K-Lite? - DON'T DO IT!
By jeanpave in forum Software PlayingReplies: 45Last Post: 15th Nov 2010, 23:04 -
I don't get it?
By penny1stu1 in forum Newbie / General discussionsReplies: 1Last Post: 5th Apr 2010, 06:34 -
don't like what's on tv?
By deadrats in forum Off topicReplies: 2Last Post: 16th Feb 2010, 10:42 -
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 08:44 -
Don't get it...WMV
By stompinne in forum Video ConversionReplies: 4Last Post: 10th Sep 2007, 05:33
