Out of these options what should I choose (best ratio for file size to quality)?
Originally Posted by Rpgamer007
Bitrate: 1750 kbps
DVD Quality for 50 mins on one cd.
2. Res: 640 x 480 ( PAL & NTSC)
Bitrate: 910 kbps
Better than SVCD Quality for 80 mins on one cd.
3. Res: 544 x 432 (PAL) 544 x 324 (NTSC)
Bitrate: 850 kbps or lower to 400 kbps
Higher bitrate is more compared to SVCD. 95 mins to 3 hours on one cd.
Don't use a lower resolution that looks very bad.
I use the third option with 700 kbps very much you get good results.
Look with a bitrate calc for the best bitrate to set.
I hope it will help you!
yysie
Greetings from Holland
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Divx Compression
By RustyBob in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2011, 18:05 -
Compression Settings General
By oc6088 in forum Video ConversionReplies: 13Last Post: 7th Oct 2009, 21:14 -
Capture Cards with hardware compression to Xvid/Divx?
By quantass in forum Capturing and VCRReplies: 7Last Post: 31st Aug 2008, 19:50 -
Dr. DivX subtitle settings
By drstupid in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 07:13
