Hello I am new here please bare with me...I have a .MKV video that is 13.2 GB but when I use BDtoAVCHD v.1.9.2 to convert to BD23 the file size ends up being 23.8 GB (25,588,735,768 bytes) which won't fit on a BD25 since it only has 22.5 GB usable space so it wont all fit on the disc, (using ImgBurn). The movie does play in my Blu-ray Player and makes it almost to end, so most of the movie is there, less the credits.
I can live with out the credits but does anyone know how to reduce the settings? (I tried the custom media settings to no avail).
Or is it just a glitch in the program?
Results 1 to 12 of 12
I can't say I've ever used the program but I'm wondering if you are using passthrough audio perhaps?
IF you keep the original audio that will eat up a lot of space. See whatever choices it has for reducing it (ie reencoding - don't worry audio encoding is loads faster than video reencoding, when done separately that is, but still won't add a huge amount of time to the conversion). Fyi ac3 at 640kpbs still sounds great even if its not lossless anymore.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Than you'll have to lower the video bitrate to make it fit. You have to sacrifice something, either video quality or audio quality.Originally Posted by autobot
Or can you use dual layer brs? Than you can just do a straight copy as if it were a dual layer dvd to dual layer dvdr. Same concept anyway. Just rip and burn no transcoding.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Yep will probably have to sacrifice the audio track will see how bd rebuilder works it also has a custom target size setting as does BDtoAVCHD will know in a few hours if the BDrebuilder can make it fit.
I could use the dual layer BD50 but they are more expensive than the BD25-RE and If I mess it up it becomes a really expensive coaster and if I go for the BD50-RE whoa $$.
So a lot more trial and error still ahead thank you for your help. -
Good luck.Originally Posted by autobot
I know its a bit different but have you considered just going the file route and using harddrives instead of br discs?
You can use ripbot264 and you can keep your original audio and just make it any size you want. Copy to a harddrive and playback. No fuss no muss.
And you can tailor it to your particular hardware player if it has certain quirks to it - ie number of reference frames, etc.
Something to think about. And a few tb harddrives would store a lot more than single layer br discs....Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Just a note,since your source is an mkv you'll need to use file-import in BDrebuilder. Since your burning on a BD25 try HighSpeed BD25 mode it's much faster than the 2-pass mode.
Success great PQ and even kept the DTS 7.1 audio tracks and it fit on the BD25!
Thank you for recommending BDrebuilder this works beautifully. -
HD Audio to FLAC > BD25?
By hogger129 in forum Authoring (Blu-ray)Replies: 8Last Post: 30th Apr 2013, 01:24 -
BD50 to BD25 and keep menus
By Eyecan'tcode in forum Blu-ray RippingReplies: 1Last Post: 24th Dec 2011, 20:26 -
BD25 Media + Bluray Player + Authoring = Inconsistency
By likwid8 in forum Blu-ray RippingReplies: 6Last Post: 15th Apr 2010, 00:15 -
bd50 t0 bd25 from another region?
By tomrip in forum Blu-ray RippingReplies: 5Last Post: 16th Oct 2009, 16:41 -
BD25 vs. DVD DL
By rysktkr in forum MediaReplies: 16Last Post: 5th Oct 2009, 14:47
