Hi All,
I'm a long time stick photographer but new to video. That said; I am working on a clip that needs color correction, shadow/highlight . . . Due to backlighting.
I created a sequence sync'd with a separate audio source, working in Premiere Pro CC. All is fine as far as the sync goes until I do the exposure corrections and then the audio is way off.
One video track, about a minute and a half and two audio tracks, one from the camera and one from a separate recorder. I will just use the separate audio track. Audio is a wav.from Tascam. Video from a D4 DSLR mov. File at 24fps.
Hope that is enough info for someone to come up with an answer?
Thanks in advance.
Steve
Results 1 to 12 of 12
Adding a color correction should not affect the sync in any way. It's possible that Premiere is unable to handle a "live" preview since a color effect is essentially another video layer. What happens if you render the sequence?
The nikon files are long-gop and require a pretty hefty system to edit natively.Last edited by smrpix; 19th Oct 2013 at 17:14.
I haven't tried rendering the sequence. I'll give that a shot but I wonder if it's my system.
The rendering issue could be it because at times the live preview hung up halfway through
My system;
Mac Pro 1.1 2 dual core 2.66 GHz processors 11 GB of RAM ATI 5770 video card.
Thanks,
Steve -
Mac and Premier are strange bedfellows at best. One is underpowered, the other bloatware. Premiere is sluggish even in Windows because the code is not optimized.
I think going into the cloud with the darn thing was the only way to break the bad legacy. -
What works better than Premier On a Mac? At this point I'm just looking for whatever works best
Mac software.
Same thing over here with Windows and iTunes. It's buggy. Apple doesn't really know all the ins and outs of Windows. It's a lot of little nuisances. Especially cutting and pasting. And if you don't go step by step in a linear fashion, and stop and wait here and there, it goes buggy.
Neither does Adobe know the ins and outs of a Mac.
Maybe FCP will work well. -
Main issue is a dual core won't cut it ( <= get the pun
) with modern HD formats like h.264 , regardless on PC or MAC
These days, Mac's and PC's have very similar hardware (intel based) spec wise
Mac version of Premiere is a different animal than the PC version; it's even slower an more buggy . A lot of it has to do with drivers and ATI cards. PC / Nvidia don't seem to have as many issues . This is discussed frequently on the Adobe forums
Best workflow for a dual core on a mac would be to re-encode to prores and use that for editing -
Umm..no, not really. It sounds like there should be a pun in there though. It has all the trappings of a pun.
A "core" is usually precut, so I don't see how it could cut anything. It's the result of a cut, no? A "coring" being the inside of a core that's been extracted, yes?
So how can a core make a cut? It's a "cutt-ee", not a "cutt-er".
Maybe my brain-o is no-bueno? Is that a pun? No. It's simply a play on words, a rhyme. Doesn't rise to the pun level.Last edited by budwzr; 23rd Oct 2013 at 18:47.
doooood are you are being serious ? Do I have to explain it with animated gif or something?
Seriously - In English there is an expression (at least in "American-ese" , I don' t know if the Brits or true "English" have this saying) that if something "doesn't cut it" then it means it's not "good enough" or "insufficient" . It might have been derived from "not making the cut" , like not making the final cut on a sports team that sort of thing (fond memories in high school for you , eh?
) - I don't know the history behind it. So what I'm saying is a dual core is underpowered for editing HD video. (He actually has an old MacPro workstation so 2x2 (so "equivalent" to a quad I guess), but it's still going to be slow compared to a modern single quad core, or modern dually workstation ) . But we're also talking about "cutting" in the sense that video editing involves "cutting" => that's the play on words
Ah-ha. The pun is on "cut", not "core" then. Right? I had it backwards I guess. That's the most complicated pun I've ever heard. Gotta be a rocket scientist to figure out that one.
I like the simpler ones better. They don't require thinking.
Hahaha
Hey, if you're not busy, help me find a flip case for my new Galaxy Note 10.1 2014 Edition Tablet. Has to be high quality. None of that leather crap. Or big borders. Something clean. Maybe they have that in the Great White North, eh?
I can't get my mind back on video til I get a decent case. It might get scratched. No China stuff. Delivery takes too long.Last edited by budwzr; 23rd Oct 2013 at 19:13.
Need a simple tool to sync up badly out of sync audio and video
By CompVid in forum EditingReplies: 16Last Post: 26th May 2013, 06:55 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
HELP: advice external video monitor options for color correcting
By DvdRookie in forum EditingReplies: 3Last Post: 14th Mar 2011, 15:20 -
Color Correcting in Final Cut Pro 7 (probably an easy question to answer)
By Huntr777 in forum MacReplies: 0Last Post: 18th Apr 2010, 11:49 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 07:53
