I converted an mpg to a vcd mpg using Video Pack 5.
The converted mpg lost some picture color quality.
The original mpg was clear and bright and the converted one
was dull and greyish.
How can I convert with the exact same quality.
TPMGEnc would not convert it...got a msg that said:
"can not open, or unsupported"
Thanks for any help
Maybe you have to fix the file with any tool or the file isn't a MPG but a AVI if that is the problem you have to change the extensions into *.aviOriginally Posted by BMzx
I hope this will help
Bye yysie -
Yysie
Thanks for the fast reply. I'm sure this is an MPG and not an AVI.
What do you mean by "fix the file with any tool " Can you tell me how to do it and what Tool. Do I fix the original or the converted MPG
Converting a color video to black and white apart from one color. Possible?
By SteveLock in forum EditingReplies: 7Last Post: 23rd Feb 2009, 09:04 -
Variable Video Picture Quality
By hoodwoods in forum Newbie / General discussionsReplies: 7Last Post: 4th Nov 2008, 23:16 -
My utube video quality IS LOST when Shrunk - HELP!!
By Entry in forum Video Streaming DownloadingReplies: 1Last Post: 4th Nov 2008, 22:55 -
Can I remove color and letterbox MPEG2 video without losing quality?
By gamgamman in forum EditingReplies: 3Last Post: 10th Jul 2008, 23:22 -
TV Capture/Convert lost my color?
By WDude in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2008, 17:20
