How do you safely clean dust off of a dvd disk without damaging it ? What do you use to wipe it off? DO you wipe in circular motion, or straight out wards? I have read so much conflicting info online. Please any help would be greatly appreciated. thanks in advance
Hold the disc by the edges. Blow off any loose debris first.
Then use a soft cloth, moistened with a mix of isopropyl alcohol and water. Most would tell you to wipe it back and forth in a radial pattern, from the edge to center. This should be good enough to remove dust and fingerprints.
Make sure the alcohol you use isn't rubbing alcohol which has menthol or other additives. -
The ones I get from the local library, I just give a quick shot of Windex and wipe with a soft paper towel.
Most of them have multiple greasy fingerprints and seem to have been used as a drink coaster on a coffee table or a Frisbee, so not easy to damage them more. A buffing wheel would be needed for a through cleaning.
My own DVDs are in better shape and don't often require cleaning. (But Isopropyl or Denatured Alcohol and a lint free cloth are probably a better choice.) -
Hold them up to your mouth.....go "Hhhhhh"....and wipe them on your jeans.
Which filters to use to clean this DVD source?
By ak24 in forum RestorationReplies: 5Last Post: 30th Jul 2011, 23:11 -
How Do I Store Video Files Safely Forever?
By Video-Guy in forum Capturing and VCRReplies: 32Last Post: 5th Feb 2011, 17:52 -
How do I clean up (trim) beginning and end of DVD?
By perceptionist in forum EditingReplies: 6Last Post: 28th Mar 2010, 00:29 -
Vdub Clean up on fuzzy videos transfered to dvd
By Konfusion in forum RestorationReplies: 10Last Post: 16th May 2009, 11:07 -
Where can i download clean and simple dvd menus?
By Anonymous70 in forum Authoring (DVD)Replies: 0Last Post: 22nd Feb 2009, 07:17
