I've tried searching but have found no answer, unfortunately most searches for interlacing bring up de-interlacing.
I have some 720x576 50p files which I am trying to put on DVD as interlaced (25i) rather than progressive (25p) to keep motion as smooth as possible.
The resulting DVD would be played on a DVD through a TV so interlaced looks better than progressive.
For information, the original footage was 25i from a minidvd camcorder but some scenes have a bit of camera shake.
I used Kdenlive VSTAB to reduce the shake (which worked very well) but this seems to produce 25p from the 25i input.
I then extracted the original video using handbrake with bob deinterlacing which produced a 50p file and have subsequently de-shaked this at 50p using Kdenlive VSTAB again giving me a smooth 50p file.
Obviously I can create my DVD with 25p but would prefer the better motion smoothness that 25i would give.
Tools available:-
Linux (Ubuntu 12.04), Kdenlive, Videostyler, ffmpeg, ffmbc, mencoder, handbrake (+ anything easily loaded in Ubuntu).
interlaced PAL DVD ?
In ffmpeg, to generate 50p => 25i TFF : -vf interlace
http://ffmpeg.org/ffmpeg-filters.html#interlace
To encode interlaced, TFF => -flags ildct+ilme -alternate_scan 1 -top 1
-target pal-dvd for PAL DVD compliant MPEG2 encoding settings
e.g for elementary video stream (you need to set bitrate as well, according to a DVD bitrate calculator, I used 6Mb/s in this example)
Code:ffmpeg -i 50p_input_file.ext -vf interlace -flags ildct+ilme -alternate_scan 1 -top 1 -target pal-dvd -b 6000k -an output.m2v
Hi poisondeathray,
Once again you've come to my rescue. It sort of worked.
The command was not compatible with my ffmpeg 0.7 and couldn't download later than 0.10.9-7 (still didn't accept interlace) into Ubuntu.
I'm concerned that a later version may not be backward compatible with Kdenlive or handbrake.
Extracted a static version which I ran with ./ffmpeg.
Got an error message related to -b , need :a or :v so added :v. Also removed the -an to get audio.
This seems to work OK.Code:./ffmpeg -i input.m4v -vf interlace -flags ildct+ilme -alternate_scan 1 -top 1 -target pal-dvd -b:v 6000k output.m2v
I seem to struggle finding the command options to use with ffmpeg, many don't seem to be in the documentation - or is it just me?
many thanks -
I just know the basic and commonly used ffmpeg commands
There aren't any good comprehensive guides, and they seem to be changing the syntax quite frequently
The reason I suggested elementary video only, is ffmpeg's muxer isn't the best (you can get stuttering) . I would use a reputable 3rd party DVD multiplexer / authoring tool like muxman (but I don't think there is a unix version ...)
LucasArts is now one with the force
By yoda313 in forum Off topicReplies: 14Last Post: 19th Apr 2013, 18:56 -
Force Subtitles
By ramhanuman in forum SubtitleReplies: 0Last Post: 14th Mar 2013, 10:34 -
Force FFDSHOW?
By therock003 in forum Software PlayingReplies: 6Last Post: 25th Feb 2012, 14:24 -
Force 16:9
By Giorgis in forum Authoring (DVD)Replies: 10Last Post: 4th Oct 2010, 02:50 -
Force autoplay
By ocgw in forum Media Center PC / MediaCentersReplies: 0Last Post: 2nd Jul 2009, 19:48
