Hello everyone,
I have a Samsung series 6 led hdtv that has built in wifi and I use my Linksys WAG200g router to stream media from my pc to tv using mezzmo. SD works fine but playing mkv's don't, I get huge lag to the point video is simply un-watchable. I understand my router only has B and G mode, no N available but I thought 54Mbps should be enough for mkv playback? I get around 90% signal strength on my tv.
Same goes with PS3, I get extremely slow download on my ps3 wirelessly so I am convinced G mode is just not enough. My router is more then 200feet away from tv so running a CAT-6 is not practical hence I am in the market looking for a new router.
What I want to confirm here is that does anyone know if Samsung series 6 TV's have built in Wireless N mode to be worth upgrading my router? I was looking at router options and this looks promising: https://www.linksys.com/en-eu/products/routers/EA6700
I know that router is an overkill but it has other nice options too like USB 3.0 for connecting my external hdd's as my mobo only have usb 2.0. Also it seems super fast if I connect another 802.11ac wireless dongle.
Another much cheaper option I was looking into is PowerLine AV Network Adapter like this: http://www.dlink.com/us/en/home-solutions/connect/powerline/dhp-306av-powerline-av-network-adapter
Its supposed to give you a 100mbit lag free Ethernet connection utilizing power sockets, does anyone has any experience with it? Is it any good?
Or is there a much better option I am unaware of for streaming my media to tv without long running cables clutter.
Thanks for any help
EDIT: To be more precise, my tv is UA46F6400.
http://www.samsung.com/ae/consumer/tv-audio-video/television/led-tv/UA46F6400ARXZN-spec
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
From TV Manual:
* This TV supports the IEEE 802.11 a/b/g /n communication protocols. Samsung Recommends using IEEE 802.11n. Otherwise when you play video over a network connection, the video may not play smoothly.
Ok this confirms that my TV does indeed have wireless N, now all it remains is to figure out either buy a better router or go some other option. -
You will have to try wireless or powerline networking with the TV to really know for sure if either will work. There are too many variables to predict results ahead of time. The speed you can get with wireless depends on your home's construction, the wireless networking equipment, where it is located, and how much interference from other wireless devices and other RF sources there is. Similar kinds of things affect powerline networking, the equipment, its location, the design of home's electrical system, and the condition of the wiring, all play a role.
That being said I have been pleased with the performance of an ASUS RT-N16 in a 1950s plaster wall home, although to be honest I have streamed very little video with it. http://www.newegg.com/Product/Product.aspx?Item=N82E16833320038 -
Hmm so what I understand is that Powerline switches are not reliable and I can't expect to get a lag free 100mbit connection out of it? Well if that's the case then why bother with it and I should just get a better wireless router.
Can I get video from my computer to my TV wirelessly?
By sdsumike619 in forum Newbie / General discussionsReplies: 24Last Post: 14th Oct 2011, 16:02 -
m2ts video steaming issue ( plays too fast)
By alolo in forum Video Streaming DownloadingReplies: 1Last Post: 6th Jan 2011, 08:58 -
Integrate HDTV/Desktop/Laptop Wirelessly?
By Kravage in forum Newbie / General discussionsReplies: 6Last Post: 22nd Aug 2010, 14:19 -
Laptop/PC to TV - Suggestions for streaming video wirelessly?
By Levahj in forum Media Center PC / MediaCentersReplies: 10Last Post: 3rd Dec 2009, 11:40 -
I need a good PMP to play Video and Audio wirelessly
By joshwake in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2008, 12:54
