Results 1 to 12 of 12
  1. Hi, I just purchase a new lcd tv. I want to know how can i connect speakers to my tv? The tv has audio input, pc audio input and coaxial. The tv has digital audio/spdif (i dont know what that means). My tv doesn't optical and audio output. I want to buy a sound bar or a home theater system. If anyone can help me out i would really appreciate it.
    Haier 32inch tv: l32d1120
    Audio Input & Coaxial
  2. What are you watching? Over the air broadcast TV? Cable/satellite TV? DVD/Blu-ray player? Ie, what is the source(s) of the audio?
  3. I'm trying to buy a soundbar or a home theater system.
    canada
    Buy a sound bar that has a digital optical input,that will work with with your tv,if you buy a home theater system then buy one with hdmi inputs and hdmi output if you are using a blu-ray player and HDTV box with hdmi output.
    I myself wouldn't use the tv output as a sound source.
  5. Originally Posted by johns0 View Post
    what cable will i need to connect to the soundbar?
  6. I'm a Super Moderator johns0's Avatar
    canada
    Digital optical cable.
  7. Originally Posted by johns0 View Post
    My tv doesnt have optical output just audio input.
  8. I'm a Super Moderator johns0's Avatar
    canada
    Just looked at the tv and it uses co-axial audio and mini headphone jack so buy a sound bar with co-axial audio and/or analog audio,not digital optical like i thought.
  9. Originally Posted by johns0 View Post
    yes it has coaxial input and a headphone input but no output so if i buy a soundbar with coaxial sound will come out?
  10. I'm a Super Moderator johns0's Avatar
    canada
    The headphone will work as analog audio out and a sound bar with co-axial input will work.The co-axial connector is audio output,not input.
  11. What cable will i need to connect?
  12. Member Cornucopia's Avatar
    That is only true & workable if the "coaxial" output listed (on the specs & manual) refer to "coaxial digital audio" and not "coaxial rf" output. Hard to tell from the extant material.
    If it is: a standard RCA cable should work.
    If it isn't: you would have to make use of the Headphone jack, which adds some complication in the way of gain structure (volume). Cabling would be slightly different in that case, depending.
