I'm having a problem with Avidemux trying to convert to AVI's, I'm semi new to this and am needing help getting my outputs set correctly to have these files play on burned discs and work on my DvD player.
I've mainly been trying:
Mpeg 4 ASP (xvid)
Two way pass 1500bit
Ive tryed thus far on the audio outputs the AAC(faac) and ACC burned on the discs the audio will completely not play.
Pretty much my audio is constantly off sync from what Ive tryed.. I just want them to line and sync up nice when I burn it on my disc and work on the DvD player. Please help if could, much appreciated if someone could correct me.
My Video Codec Info:
Stream 0
Type: Video
Codec: H264 - MPEG-4 AVC (part10)(avc1)
Resolution: 1440x1080
Stream 1
Type: Audio
Codec: MPEG AAC Audio (mp4a)
Sample Rate: 48000 Hz
Channels: Stereo
Then I misunderstood. Nothing I came across listed playing AVIs of any kind. About all I discovered remotely useful about the player is that it can be hacked to play out-of-region DVDs. So, these XviD AVIs you make play, but out-of-synch?
Does this program convert MKV's that you listed?
Out of sync audio after converting .avi to .mkv
By ATOJAR in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jul 2013, 04:50 -
MKV to AVI Audio Sync Problem
By adalect in forum Video ConversionReplies: 26Last Post: 18th Dec 2012, 03:09 -
.mkv to .avi audio is out of sync
By gartzo in forum Video ConversionReplies: 3Last Post: 10th Jun 2011, 16:12 -
audio sync issues after converting mkv to iso and burning to bd-r/dl disc..
By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 15:03 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
