Is there a freeware program(s) other than MultiAVCHD, that can take individually ripped episodes from Blu-Ray discs, and accept them without re-encoding. A very simple menu to select the titles would ideal.
The program ideally should keep Forced Subtitles, and if possible, keep the original chapter timings.
Thanks all for your suggestions.
-The Mang
No, there isn't, AFAIK.
There is one but I think it recodes.
I have wished that some developer would get a project going like this.
It would come in handy in some situations, for instance, multiple dvd titles and captured HD digital tv.
Blu-ray format is unfriendly to end users for a lot of reasons.
The low and mid-priced editors/authoring progs. want to re-encode as well. -
Why not use multiavchd?It does all you ask for.
-The Mang
Make sure you have java,ffdshow and haali splitter installed to use multiavchd.
My wishes may be answered soon with BD Rebuilder. http://forum.doom9.org/showthread.php?p=1648224#post1648224
-The Mang -
That's good news...I have wondered why no devs have worked on simple authoring with blu-ray material before now.
I hope he can make it so it won't re-encode the material. -
I have a question. I have Star trek - The next generation on original Bluray discs, and i want to putt croatian subtitle in that episodes. I did it with tsMuxer, but hi's joined two episodes into one file, so that two episodes are become one file with 1:30:00 hrs lenght. I want two separate episodes with sub in them. Is it possible and how? Please reply me on electronicmaestro1@yahoo.com because i'm not here often. Thanks to everybody.
simple blu-ray conversion
By cynikalhedonist in forum Authoring (Blu-ray)Replies: 16Last Post: 10th Dec 2010, 01:15 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 23:58 -
simple sw to re-author Blu Ray
By Oktober in forum Authoring (Blu-ray)Replies: 2Last Post: 16th Jul 2010, 05:24 -
How do I backup blu-ray TV Show disc into individual episodes?
By WPlotkin in forum Authoring (Blu-ray)Replies: 2Last Post: 8th Jan 2010, 22:50 -
Multiple blu ray titles-No menu with AVCHDcoder or MultiAVCHD?
By thegeeman in forum Authoring (Blu-ray)Replies: 6Last Post: 22nd Sep 2009, 09:22
