  1. Hi
    in attach I have a .avi mpeg2 file, but I can not find any suitable decoder to read it in virtualdub and on windows, but I need load it on virtualdub. VTag=Mpg2
    I'm on windows xp 32 bit, please where I can find a codec for it?
    Thank you
    Tried the mpeg2 plugin ?
    http://gral.y0.pl/~fcchandler/Plugins/MPEG2/
    If it fails try then remux the avi to a mpg file with for example ffmpeg,
    ffmpeg -i video.avi -acodec copy -vcodec copy newvideo.mpg
    and open the mpg in virtualdub.
  3. DECEASED
    Jun 2009
    Heaven
    ffdshow VfW interface.
  4. thanks, now I have continued here https://forum.videohelp.com/threads/359578-Virtualdub-as-frameserver?p=2274637#post2274637
    hoewver using ffdshow in virtualdub it open my mpeg2 video file wrong: because it use mpeg1 decoder in place of mpeg2. It's strange because the vtag into the .avi files is correctly mpeg2 and original files are mpeg2 hd file
    I have transcode with: ffmpeg -i c0020.mxf -vcodec copy -an output.avi
    so output.avi have to be a mpeg2... mediainfo says:
    General
    Complete name : D:\ouput.avi
    Format : AVI
    File size : 219 MiB
    Duration : 36s 600ms
    Overall bit rate : 50.1 Mbps
    Writing application : FFmbc 0.7
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : 4:2:2@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Codec ID : mpg2
    Codec ID/Info : (MPEG-1/2) FFmpeg
    Codec ID/Hint : Ffmpeg
    Bit rate : 50.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.965
    Stream size : 219 MiB (100%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    This is original mxf:
    General
    Complete name : d:\C0020.mxf
    Format : MXF
    Commercial name : XDCAM HD422
    Format profile : OP-1a
    Format settings : Closed / Complete
    File size : 263 MiB
    Overall bit rate : 60.3 Mbps
    Encoded date : 2013-05-24 22:12:18.000
    Writing application : SONY Opt 1.22
    Writing library : SONY Opt 1.22
    Video
    Format : MPEG Video
    Format_Settings_Wrapping : Frame
    Color space : YUV
    Bit depth : 8 bits
    Stream size : 218 MiB (83%)
    Audio #1
    Format : PCM
    Format settings, Endianness : Little
    Format_Settings_Wrapping : Frame (AES)
    Bit rate mode : Constant
    Bit rate : 1 152 Kbps
    Channel(s) : 1 channel
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Stream size : 5.03 MiB (2%)
    Audio #2
    Format : PCM
    Bit depth : 24 bits
    Audio #3
    Format : PCM
    Bit depth : 24 bits
    Audio #4
    Format : PCM
    Bit depth : 24 bits
    Audio #5
    Format : PCM
    Bit depth : 24 bits
    Audio #6
    Format : PCM
    Bit depth : 24 bits
    Audio #7
    Format : PCM
    Bit depth : 24 bits
    Audio #8
    Format : PCM
    Bit depth : 24 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Time code of first frame : 01:34:21:15
    Time code settings : Striped
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    Using -vcodec copy it have certainly a mpeg2... how is possible it have to be a mpeg1 file?
    Maybe is ffdshow load the wrong decoder
    Using mpeg1 image are pixelated, jerky video, 1° first frame blak, bad result
    [Attachment 20614 - Click to enlarge]
