Hi there!
I have a Mkv Video file that is like an Hour long,
I want to remove the first minute of the video. and later in the middle i want to remove the 12 and 13 minute..
is there an easy and fast way to do so ?
Without loosing the quality of course ?
Thanks !![]()
Solveigmm AVI Trimmer, select the parts you want to keep and add to the list, save as a new mkv.
Avidemux, open mkv, select the parts you want to remove and press delete, under video and audio choose copy, under format choose mkv, save as new mkv.
If you have a mkv with several audio tracks and subtitles use instead Mkvtoolnix, see https://forum.videohelp.com/threads/359121-How-to-extract-parts-from-a-mkv-including-al...ubtitle-tracks
But you can't cut exactly, only at keyframes and they can be several seconds a part.
How to edit mkv file??
By avan93 in forum Blu-ray RippingReplies: 2Last Post: 6th Jul 2013, 11:02 -
Edit .mkv file (split/join) - nothing works "properly"!!!
By The.King in forum EditingReplies: 19Last Post: 11th May 2013, 06:23 -
How to edit MKV Tags? Is there any MKV Tag Editor available?
By Bonie81 in forum Video ConversionReplies: 1Last Post: 6th Nov 2011, 11:20 -
Can't open MKV file ripped from DVD - Plays in VLC but not in edit programs
By dsunbury in forum DVD RippingReplies: 3Last Post: 7th Apr 2011, 05:21 -
Eliminate embedded subitle MKV file - edit after with Any Video Converter?
By Ze Tomes in forum SubtitleReplies: 6Last Post: 23rd Nov 2010, 15:46
