I have an old Sony camcorder (video8, CCD-F455E Pal) which is suffering from the dreaded "triangle of death" but I've discovered I can still use it as a webcam if I connect it via a tv card. The only problem is it shuts off every 5 minutes. This is a normal function of any video camera or VCR when set in record mode but paused, it's to stop damaging the tape or the mechanism. What I'd like to know is if it's possible to modify the camera to stop it shutting off after 5 minutes? I don't care about damaging the camera by cutting wires or removing a component for example as it's of no other use to me.
Well, I can't speak to that specific camcorder, but others (Canons and Panasonics) I've used don't auto-shutoff if you simply don't put a tape in them. Have you tried that?
Steve -
There's no tape in it and it still shuts off. The only way I could stop it shutting off is to put a tape in and record - which I can't as the tape mechanism doesn't work too well.
some old canons would stay on without a tape if you left the tape door open.
modifying frames
By tonyalcapon in forum EditingReplies: 12Last Post: 1st Jan 2013, 17:20 -
Sudden appearance of noise with Sony CCD-TR6 (Video8)
By mOOm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 23rd Jul 2012, 00:48 -
Modifying bluray subtitle files
By agent154 in forum SubtitleReplies: 2Last Post: 20th May 2012, 14:08 -
Tape stuck in Sony Video8 camera
By ldemer in forum Newbie / General discussionsReplies: 0Last Post: 26th Jul 2011, 19:05 -
Modifying NTSC MPEG-2 with Restream
By Anonymous344 in forum Video ConversionReplies: 18Last Post: 25th Mar 2010, 17:11
