I've finallly got video with my audio when converting avis to (S)VCDs with TMPGEnc 2.53. I thought Divx 5 would be the only codec I needed...no, I needed v4 as well!
The problem I have now is a bit bizarre - I've got a small block of white sqaures in the top-right hand corner of the screen. It's 3x3 white squares, with the top-right hand conrner square black.
Sorry I can't explain it any more clearly, but has anyone seen anything like this before?
Thanks again for your help.
Chris.
OK, after a bit more experimenting... Sorted :P
It's just the software players that are showing this (WMP8 & Elecard) and only when playing mpgs in SVCD format, so I guess it's a codec problem?
Anyway, the reason for converting these avis (my Dansai standalone DVD player) works fine. woo hoo! :P
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 23:03 -
A font with only squares, how to create?
By sybariten in forum ComputerReplies: 3Last Post: 21st Feb 2008, 16:38 -
Squares Appear When Playing Online Games - Resolved
By HacktheHacker in forum Software PlayingReplies: 6Last Post: 20th Jan 2008, 17:07 -
Colour Avi (or mpg) to black and white
By cawright1 in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2007, 07:00 -
3d Games Cause Large Squares on Screen - SOLVED!
By HacktheHacker in forum ComputerReplies: 11Last Post: 29th Jun 2007, 20:59
